March 6, 2014, 18:21 |
wind turine blade periodic
Papis
Rep Power: 15 |
Hello all,
I am trying to mesh a wind turbine blade using 120 degrees periodic conditions.The input that I have is the iges file which contains the whole blade geometry.I build all the required geometry using ICEM. Because I have the whole blade i need to cut it at the periodic boundaries to match the periodic faces. The problem is that when mesh generating(first cell at 1e-06) , volume orientation problems are created exactly at the root region(where the periodic meets the blade) where the blade geometry is almost a cylinder(I say that to imply that the blade geometry there is smooth). Do I have to use a CAD preprocessor to create the cuts and the whole model and then use ICEM for meshing only or does ICEM can handle this kind of things? I asking a kind of generic question because I am not sure whethere there is something wrong with the meshing params(blocking,bunching etc) or is a surface problem in generation of geometry. I have the basic geometry in pictures attached for better understanding of my issue. Any information would be really helpful. |
March 10, 2014, 05:33 |
Sebastian Engel
Rep Power: 20 |
in ICEM, there is a feature to create curves by intersecting surfaces. With this curve you could trim surfaces of the blades base. I can't check right now, there are two ways to trim these surfaces. creating curves with a curve feature or using a feature of the surface page. |
Problem in conducting CFD of analysis of wind turbine blade | atulpat | CFX | 16 | August 17, 2013 04:09 |
Wind Turbine Blade rotation | mmd_knr | FLUENT | 1 | August 8, 2012 14:52 |
simulating wind shear profile for a wind turbine--> How??? | mohammad | FLUENT | 0 | April 14, 2012 23:54 |
Calculating lift force of a wind turbine blade problem | LittleBart | CFX | 4 | June 29, 2011 02:33 |
Mathematical analysis of the cyclic stresses in the Wind Turine Blade Root | milindashokshende | Main CFD Forum | 1 | May 26, 2010 10:36 |
