[ICEM] Imported geometry in Solidworks (CATPart) for ICEM meshing
Like Tree1Likes
  • 1 Post By Crank-Shaft
Old   March 9, 2014, 19:32
Default Imported geometry in Solidworks (CATPart) for ICEM meshing
lcaBR is on a distinguished road
Hi guys! I really need a hand here, hope you can help the newcomer =D
I've got this geometry (it is an aircraft engine nacelle) in .CATPart extension but we don't have a Catia license here at university. I've managed to open it in Solidworks and it works fine, all the surfaces are there as "imported surfaces" and I'm able to select surfaces boundaries and points.
I'll have to export this geometry to ICEM for meshing, so here's the question: does meshers such as ICEM recognize these "imported surfaces"? Should I convert these entities into something before exporting the geometry?
Thanks a lot guys!
Cheers
lcaBR is offline   Reply With Quote
Old   March 10, 2014, 05:34
Crank-Shaft's Avatar
Ovi
Crank-Shaft is on a distinguished road
Have you tried to Save As>Parasolid ?
A Parasolid or an IGES file easily imports into ICEM most of the time.
diamondx likes this.
Mechanical Engineering
Sydney, Australia
Crank-Shaft is offline   Reply With Quote
[snappyHexMesh] Open surface - geometry imported from solidworks augusto.s.b OpenFOAM Meshing & Mesh Conversion 1 April 24, 2013 23:17
[snappyHexMesh] Meshing geometry not visible in paraView. Nikunj.R OpenFOAM Meshing & Mesh Conversion 4 October 2, 2012 15:45
[ANSYS Meshing] Geometry and meshing of a static mixer parradux ANSYS Meshing & Geometry 9 September 9, 2012 07:29
[ICEM] Meshing adjacent wall geometry and simple ICEM questions everdimension ANSYS Meshing & Geometry 25 June 20, 2012 04:25
IGES/IGS format geometry file for icem meshing littlelz Main CFD Forum 0 May 27, 2008 18:24
