Home > Forums > ANSYS Meshing & Geometry
[ICEM] Using "ic_surface multiple" command in batch mode
Old   March 11, 2014, 05:24
Default Using "ic_surface multiple" command in batch mode
Gergely Hajgató
Egrego is on a distinguished road
Hello everybody,
I'm facing a scripting problem in ICEM CFD, whose solution has to be simple, but I can't figure it out.
I'm trying to use the "ic_surface multiple" command in a script file, exactly as below:
ic_surface multiple SURFS srf.00 {{arista.14 spine.57 arista.2 spine.38} 0 1 0}
The batch file runs without error messages, but the surface doesn't get generated. When I copy the exactly same line to ICEM's message window, it works fine. Could anybody tell me, how I could make it work in the script file too? Thanks for your help in advance!
Egrego is offline   Reply With Quote
Thread Tools
Trackbacks are On
Save images using Fluent in batch processing mode dixitked FLUENT 6 June 1, 2015 08:42
to run a replayfile in batch mode from UNIX froztbear ANSYS Meshing & Geometry 4 May 13, 2014 08:00
Running Ansys in BAtch Mode kuleuvenstudent ANSYS 0 November 5, 2010 13:27
cfdpost in batch mode taichijulie CFX 1 October 25, 2010 15:29
Prosurf in batch mode Dhruv CD-adapco 1 September 19, 2005 18:02
