[ICEM] Cells have only wall faces error in Fluent |
March 18, 2014, 05:31 |
Sparsh Chadha
Hello all!
I am trying to mesh a Mercedes Mclaren model (3D) in ICEM CFD. I am using robust octree method and generating an unstructured mesh as of now. I will generate the prism mesh after this problem is fixed. After generating the mesh, I run check mesh under the edit mesh tab and get error on non manifold points. I thought about going in 2 ways after this. One was to ignore the error and import the mesh in fluent. When I did this, I got an error reading 1 cell has only wall faces and unfortunately fluent wont run with this error. When I tried to locate the cells with problems, I found a very poor quality mesh nearby areas where a curved surface (basically a fin) intersects with the engine hood. I have attached the images. I tried to reduced surface mesh size, node mesh size in this area but all in vain. I have already cleaned up my geometry using topology tab but still this one problem of cells with only wall faces persists. Its been over 2 weeks and I am not able to find the solution. When I tried to fix non manifold vertices, ran check mesh again, I got errors in volume orientation and surface orientation and uncovered faces. Unfortunately the mesh worsened for Fluent. Expecting a reply from someone!!! full car.jpg problems.jpg |
Display Modes | |
Natural convection in a closed domain STILL NEEDING help! | Yr0gErG | FLUENT | 4 | December 2, 2019 00:04 |
[Commercial meshers] Mesh conversion problem (fluent3DMeshToFoam) | Aadhavan | OpenFOAM Meshing & Mesh Conversion | 2 | March 8, 2018 01:47 |
[Netgen] Import netgen mesh to OpenFOAM | hsieh | OpenFOAM Meshing & Mesh Conversion | 32 | September 13, 2011 05:50 |
UDF for wall slipping | HFLUENT | Fluent UDF and Scheme Programming | 0 | April 27, 2011 12:03 |
