[ICEM] Delete family part not possible
Old   March 6, 2014, 04:40
Default Delete family part not possible
Deutschland
FluidCFD is on a distinguished road
I accidently created an object I don't know how (named Hilfsflaeche, yellow mesh, bottom right corner, in attached picture) which is meshed as quad but the info says it contains neither geometry, nor mesh or blocking. Trying to delete it with RK -> Delete in the parts tree does not work as it seems to be included in other parts. At first, it is deleted in the tree, but when I hide another part (e.g. tank) it reappears as part in the tree. The solutions mentioned in the forum like "Delete, save, close meshing/blocking and open it again" did not work. How can I get rid of this object? It is in the middle of my normal mesh and does not belong there.
I already tried to remove it by deleting its nodes in the mesh, but then I can't export the mesh to cfx anymore.
Any hint is very appreciated.
Best regards
G.
FluidCFD is offline   Reply With Quote
Old   March 6, 2014, 08:56
Far
Sijal
Far has a spectacular aura aboutFar has a spectacular aura about
Send a message via Skype™ to Far
Is it some material point? Are you using ICEM via workbench?
Far is offline   Reply With Quote
Old   March 6, 2014, 09:03
Deutschland
it should not be a material point. This is what ICEM says:
Info for part HILFSFLAECHE
Geometry Info ----
No geometry in part HILFSFLAECHE
Mesh Info ----
Part contains 16 element(s)
Part contains type QUAD_4
Mesh area of part is 0.00637482
Bounding box around part is {-0.0308056 1.622 -0.242367} {0.0332072 1.72321 -0.225562}
Blocking Info ----
No blocking in part HILFSFLAECHE
I use ICEM as standalone and then Workbench to import the ICEM file in Pre.
My actual problem is in Pre:
Unable to import mesh: Invalid local face number (0) for element 36556 in 2D region MANTELFLAECHE_1.
I thought this could have to do something with the part Hilfsflaeche. That's why I want to get rid of it.
Best regards
G.
Old   March 6, 2014, 09:16
Far
Sijal
can you share the file?
Old   March 6, 2014, 09:21
Deutschland
I guess you are talking about the .cfx5 file. Here it is.
I already tried to manually delete the Hilfsflaeche text in the file but did not help. Well, that's not the preferred way, anyway.
Old   March 6, 2014, 09:46
Far
Sijal
I am talking about ICEM CFD file
Old   April 4, 2014, 08:57
Deutschland
for the ones having similar problems:
It was a problem of wrong associations. What helped me also:
- Using scan planes (right click on premesh and use scan planes) to locate the problem areas.
- "Edit mesh -> Convert mesh type -> Tet to Hex" for the part Hilfsflaeche. After that I could import the mesh in Pre without problems.
Best regards.
G.
how to set periodic boundary conditions Ganesh FLUENT 15 November 18, 2020 06:09
[ICEM] What is the difference between a Part and a Family? AdamAL ANSYS Meshing & Geometry 1 January 26, 2014 11:38
replacing of shock tube high pressure part with a boundary condition for low pressure immortality Main CFD Forum 0 May 2, 2013 13:30
what boundary condition is proper for simulation of shock-tube low pressure part? immortality OpenFOAM Running, Solving & CFD 0 May 2, 2013 13:22
