[ICEM] ICEM CFD Build Topology
Like Tree2Likes
  • 1 Post By robboflea
  • 1 Post By Far
Old   February 13, 2012, 17:11
Default ICEM CFD Build Topology
Dave
Dave442 is on a distinguished road
Hi all,
I am newish to ICEM CFD and I am working with .stl data for the first time. I have a .stl file which I can import into ICEM and use to generate curves and surfaces. The resulting topology appears to be in good agreement with the .stl mesh, which is great!
In my experience, however, generating a single surface from a faceted surface results in some amount of error. I have been reading the manual, however, and I cant seem to figure out whether it is possible to quantify exactly how much detail is lost during the build topology procedure. Is it based purely on the specified tolerance?
Any advice would be greatly appreciated!
Thanks,
Dave
Dave442 is offline   Reply With Quote
Old   February 14, 2012, 09:40
PSYMN's Avatar
Simon Pereira
PSYMN has a spectacular aura aboutPSYMN has a spectacular aura about
Build topology doesn't lose detail, it simply "joins" entities within that tolerance...
The joining is done at the topological level, the STL facets are not changed.
Just keep the tolerance smaller than your local mesh size and it won't be a problem.
Please help guide development at ANSYS by filling in these surveys
Public ANSYS ICEM CFD Users Survey
This second one is more general (Gambit, TGrid and ANSYS Meshing users welcome)...
CFD Online Users Survey
PSYMN is offline   Reply With Quote
Old   February 14, 2012, 11:28
Dave
Hi Simon,
Thanks for the response. I understand the build topology function better now.
Much appreciated!
Dave
Old   July 24, 2013, 08:23
robboflea is on a distinguished road
I have a question related to the build topology tool and Simon's post.
Let's say for example that when importing a stp file the build topology gives me a correct color for the edges from a tolerance greater than 0.01mm.
However my minimum mesh size can be much smaller than that. Now my understanding was that, after using build topology with a tolerance of 0.01 all double edges appearing with higher tolerances are merged. After this the model is completely closed and it is possible then to mesh it careless of the smallest element size dimension. But this conflicts with Simon's suggestion to set the tolerance smaller than the minimum element size.
Or am I wrong and the right way to repair the geometry is to use as simon suggested a tolerance smaller than the smallest element size and then manually remove all double edges?
In both cases should the surfaces associated with the modified edges be deleted and rebuilt from the newly moved edges?
Thanks a lot for your help in advance
Rob
harsh_999 likes this.
robboflea is offline   Reply With Quote
Old   October 27, 2013, 06:09
Harshad
harsh_999 is on a distinguished road
Hi all,
I've a same Q as Rob has asked
In my case,I've kept build topology tolerance as 0.05
I've assigned in part mesh setup a minimum size limit for each part which is >0.05
Is this a correct approach?
Please help
Thanks
harsh_999 is offline   Reply With Quote
Old   October 27, 2013, 09:13
Far
Sijal
Far has a spectacular aura aboutFar has a spectacular aura about
Send a message via Skype™ to Far
Originally Posted by harsh_999 View Post
Hi all,
Please help
Thanks
check the model that you are not losing any important details. rule of thumb : tolerance = 1/10 of the min curve length in model.
cesarcg likes this.
Far is offline   Reply With Quote
Old   March 27, 2014, 12:40
lcaBR is on a distinguished road
Hi guys! Sorry to revive this topic, but I have a similar question regarding aspects of build topology.
I've got this geometry which has an outlet surface. If I set a build topology tolerance of 1, the edge of this surface gets red, as it should be, once this boundary is connected to another surface.
However, if I set a tolerance of 0.0001, the edge(s) gets yellow, therefore meaning a gap exists there. Why 0.0001? Because my minimum element size is supposed to be 0.001 (Boundary Layer elements), and there is this suggestion of using tolerance = 1/10th of the minimum element size.
Question is: will I have trouble using the tolerance equals to 1, as this value gets me connected edges (red edges)? If so, the solution would be to make another geometry more precisely on CAD?
lcaBR is offline   Reply With Quote
Old   March 27, 2014, 15:32
kad
kad will become famous soon enoughkad will become famous soon enough
Your build topology tolerance might be in the range of your model tolerance. Try reducing the model tolerance under settings->model.
kad is offline   Reply With Quote
Import Mesh from ICEM CFD to CFX Andre Almeida CFX 16 April 19, 2016 03:42
Learn ANSYS ICEM CFD easy_astronaut ANSYS 2 December 15, 2013 15:34
icem cfd ai environment 11.0, laptop keyboard problem, linux pertupd Hardware 3 October 3, 2011 08:27
[ICEM] Export unstructured periodic mesh from ICEM CFD to Fluent ivanddd ANSYS Meshing & Geometry 1 February 3, 2011 00:51
How about ICEM CFD M.Gao Main CFD Forum 1 November 15, 1999 04:15
