-   ANSYS Meshing & Geometry (https://www.cfd-online.com/Forums/ansys-meshing/)
-   -   [DesignModeler] simply model, empty box (https://www.cfd-online.com/Forums/ansys-meshing/132301-simply-model-empty-box.html)
conquer March 28, 2014 19:26
Hello everybody, I have simply problem..I need to create a empty box with thickness of walls 30 mm, Box have dimensions 0,5 m x 0,5 m x 0,5 m. I do this steps:
1. I create box, with earlier dimensions
2. with tool Thin/surface I set thickness of walls 30 mm
3. then I hide surfaces on side for next step
4. and then with tool "fill" I select interior surfaces of box to fill that volume inside box
, and I have now solid (box), and fluid inside box
Problem is in meshing, because there is no contact between meshes of fluid region and solid part. I do some on changing meshing method and similar, but helpless. I need this model for thermal analysis. I will be very appreciative for any suggestion. and sorry for poor english
King regards
