[ICEM] Prism layer issue
Old   April 7, 2014, 10:03
Default Prism layer issue
itsme_kit is on a distinguished road
Hi
I set the quantity of prism layer into 3
However, at the conner of building, the third layer vanished (probably I didn't use correct words to describe the problem, but you can see it clearly in the attached pic)
Thanks for your help in advance
itsme_kit is offline   Reply With Quote
Old   April 7, 2014, 15:44
siw
Stuart
siw will become famous soon enough
I'll take a guess from your picture, since the first two prism layers look the same height, that you did not float the prism layers.
If you did not then give that a try. Set the initial height and total height to 0 and just let ICEM build a few layers itself. There's lots of posts about floating prism layers if your stuck - particularly PSYMN's presentation/document. You'll want to be working to get enough prism layers for your simulation and a smooth volume transition between the last prism and first tetra - which is not what your picture shows.
siw is offline   Reply With Quote
Old   April 8, 2014, 02:32
Ludvik is on a distinguished road
Set up "Max prism angle" to 180 (degree).
Ludvik is offline   Reply With Quote
[ICEM] Steps of generating prism layer TommyLui ANSYS Meshing & Geometry 2 September 8, 2011 17:01
[snappyHexMesh] snappy hangs while layer generation bastil OpenFOAM Meshing & Mesh Conversion 3 October 29, 2010 07:19
Why only one prism layer generated xiaoyoyo ANSYS Meshing & Geometry 0 August 26, 2010 20:17
Prism layer advice needed for port flow case MaxCFM ANSYS Meshing & Geometry 0 October 2, 2009 08:42
errors Fahad Main CFD Forum 0 March 23, 2004 13:20
