[ANSYS Meshing] inflation on the face other than source face of sweep meshing?
Old   April 16, 2014, 04:11
Default inflation on the face other than source face of sweep meshing?
jayash kumar
jayash is on a distinguished road
Hello all
i have a inverted T type geometry in 3 D. geometry having 1 part body with 2 solid one is vertical column and second is horizontal. since vertical column placed above the horizontal. i have done sweep mesh longitudinally by selecting side faces.
i would like to create inflation layers on the surface of horizontal beam surround vertical column square area. please help
thanking you in advance....
jayash is offline   Reply With Quote
[swak4Foam] swak4foam building problem GGerber OpenFOAM Community Contributions 54 April 24, 2015 16:02
Trouble compiling utilities using source-built OpenFOAM Artur OpenFOAM Programming & Development 14 October 29, 2013 10:59
centOS 5.6 : paraFoam not working yossi OpenFOAM Installation 2 October 9, 2013 01:41
[swak4Foam] Error bulding swak4Foam sfigato OpenFOAM Community Contributions 18 August 22, 2013 12:41
[swak4Foam] build problem swak4Foam OF 2.2.0 mcathela OpenFOAM Community Contributions 14 April 23, 2013 13:59
