Home > Forums > ANSYS Meshing & Geometry
[DesignModeler] adding features on existing geometry
Old   April 20, 2014, 11:47
Default adding features on existing geometry
Far
Sijal
Far will become famous soon enoughFar will become famous soon enough
Send a message via Skype™ to Far
I want to add some features in existing cad model of centrifugal compressor:
1. I want to extract hub curve. This curve should pass between two blades, something like periodic curve. I used to do it in gambit very easily using various virtual vertices placed on face.
2. Drawing of casing curve. This curve should be at some distance from blade tip which is typically 2% of blade height. In gambit i used to create edges on blade tip surface, putting mid points on each curve and then reflecting these vertices i was able to get the curve which is at uniform distance from tip e.g. 2 cm from blade tip...
Geometry file is attached here : https://dl.dropboxusercontent.com/u/...ompressor.agdb
Far is offline   Reply With Quote
Thread Tools
Trackbacks are On
[DesignModeler] Fill tool - grouping the faces of a complicated geometry? HeikkiT ANSYS Meshing & Geometry 8 July 20, 2016 07:37
problem when imported geometry from 3D CAD to star ccm, TAREK GANAT STAR-CCM+ 1 May 21, 2013 22:15
[Workbench] Meshing and export mesh from STL geometry alerfreire ANSYS Meshing & Geometry 0 March 26, 2013 10:25
Problem Importing Geometry ProE to CFX fatb0y CFX 3 January 14, 2012 20:42
2D geometry to 3D geometry Sgonzalezg ANSYS Meshing & Geometry 11 April 8, 2011 11:02
