[ANSYS Meshing] different structure in .msh format
Old   April 21, 2014, 13:15
Default different structure in .msh format
Mahsa Ghaffari
ghafarimahsa is on a distinguished road
I wrote a Matlab code to create mesh structure. My mesh is quadrilateral surface mesh for vascular. I create a mesh structure based on the following document. However, when I create simple tubular surface mesh with CFX .msh format is completely different in terms of faces. I want to know which one is actually .msh file and which rule is the one that I should pursue.
Thank you.
in the PDF the format: each face is connecting two points and two other indices will be used to show the right and left side cell index that the face is connecting.
(13 (2 1 2 2 2)(
1 2 1 2 % Here two first columns are points index &two other one cell indices
3 4 2 3))
However, in the ANSYS CFX forth first column are point indices and two other (zeros) are cell indices which are zeros because of surface mesh.
(13 (0 1 e0 0 0))
(0 "Faces of zone NURBS_CYL")
(13 (4 1 e0 3 4)(
83 8b 89 81 0 0
69 71 72 6a 0 0
a9 b1 b2 aa 0 0
e9 f1 f2 ea 0 0
29 31 32 2a 0 0
43 4b 49 41 0 0
1 2 3 4 0 0
c1 c9 ca c2 0 0
https://www.sharcnet.ca/Software/TGrid/pdf/ug/appb.pdf
ghafarimahsa is offline   Reply With Quote
.msh format, mesh 3d, surface mesh
[ANSYS Meshing] Export mesh ( .msh) in a ASCII format pedroxramos ANSYS Meshing & Geometry 14 June 20, 2020 12:30
[Commercial meshers] Problem converting fluent (.msh) into .foam format with very big mesh Balti OpenFOAM Meshing & Mesh Conversion 8 June 20, 2013 16:43
[Commercial meshers] multiplying diameters to 0.001 in a grid that has the .msh format babakflame OpenFOAM Meshing & Mesh Conversion 4 May 5, 2013 07:10
[Commercial meshers] Exporting from V grid to fluent, .msh format Karl SG OpenFOAM Meshing & Mesh Conversion 0 April 14, 2013 23:33
The format of .msh file for fluent scubme FLUENT 2 October 18, 2004 22:50
