May 6, 2014, 04:26 |
ICEM Surface problem
Simon
Rep Power: 12 |
Hey,
I´ve got a problem with generate a surface in ICEM. I want to create a surface including 4 curves (pic.1). The surface is "ok" (pic.2). But when i´m looking closely (pic.3), you can see that there is an additional curve and the surface isn´t referenced on the curve, which was choosen. Can anybody explaine whta was happend? thx Simon 1.jpg2.jpg3.jpg |
May 7, 2014, 06:27 |
Javi
Hi Simon,
You can try to set up a better tolerance number for you curve. Have you tried to see the curve with "show full" option? |
May 7, 2014, 06:48 |
Simon
Rep Power: 12 |
Thanks,
but I think "show full" is only a viewing option and no tolerance option? |
May 7, 2014, 07:15 |
Javi
Do you have geometry file? Can you share it?
May 7, 2014, 08:34 |
#5 | |
Rep Power: 24 |
You are right, but the option "show full" displays the surface triangulation as it actually is. The other options show simplifications of your model. |
May 7, 2014, 08:40 |
Simon
Rep Power: 12 |
Thank you,
now it works. |
June 6, 2014, 04:33 |
Simon
Rep Power: 12 |
i´ve got a problem with the geometry tool in ICEM. I want to close a gap between surfaces on an edge. I ´ve got a very thin first layer and when there is a gap, there will be a wrong mesh. I tried the tool to close the gaps, but I think the tolerance is to high. How can I adjust the merge tolerance? Thx |
[Gmsh] Error : Self intersecting surface mesh, computing intersections & Error : Impossible | velan | OpenFOAM Meshing & Mesh Conversion | 3 | October 22, 2015 11:05 |
[ICEM] Simple meshing problem in ICEM | fkh | ANSYS Meshing & Geometry | 6 | February 14, 2012 13:01 |
[ICEM] Problem making structured mesh on a surface | froztbear | ANSYS Meshing & Geometry | 4 | November 10, 2011 08:52 |
[ICEM] Problem making structural mesh on a surface | froztbear | ANSYS Meshing & Geometry | 1 | November 10, 2011 08:52 |
ICEM meshing problem | Forrest | CFX | 4 | May 25, 2005 18:37 |
