May 7, 2014, 13:37 |
Meshing a Bifurcation using Hexa
Daniel
Rep Power: 21 |
Hello to all
I am trying to mesh a bifurcation geometry. I have managed to generate an unstructured mesh using Tetra/Mixed method. However I am wondering if it possible to get a mesh like this one in ICEM using usual blocking? Thanks in advance D. Khazaei |
May 7, 2014, 13:56 |
Rep Power: 24 |
Check out Simon's Tipps and Tricks documentation. It has a detailed description for blocking a very similar geometry (fork).
May 7, 2014, 14:02 |
Daniel
Rep Power: 21 |
May 7, 2014, 14:07 |
Javi
Rep Power: 16 |
Hi Daniel,
I wondered the same thing few months ago, and as Kad said, simon'tips has two approaches. Here the link (see 85 & 86 slides) Simon's tip |
May 7, 2014, 14:13 |
#5 | |
Daniel
Rep Power: 21 |
I will read this PDF and come back. |
May 7, 2014, 15:11 |
Daniel
Rep Power: 21 |
I don't think that blocking produce high quality mesh for circular tube at bifurcation region.
This is how I want the mesh look like: |
May 7, 2014, 21:15 |
Daniel
Rep Power: 21 |
I have tried to do the blocking as Simon suggested in his tips and tricks.
However, I don't know how to fix it: |
May 8, 2014, 06:14 |
Javi
Rep Power: 16 |
Hi Daniel,
I´ve tried with a geometry similar to yours. The problem was the same, just the junction surface. Please, can you share your geom? |
May 8, 2014, 08:10 |
#9 |
Daniel
Rep Power: 21 |
May 8, 2014, 09:15 |
#10 |
Rep Power: 24 |
May 8, 2014, 09:22 |
#11 | |
Daniel
Rep Power: 21 |
However, about vertex and edge association: It is a CAD geometry and there are to many curves there. Do you think that the sharp angle in my blocking strategy is responsible for this problem? |
May 8, 2014, 09:44 |
#12 |
Rep Power: 24 |
The sharp angle could be a minor problem, but in general blocking should be doable. Your blocking looks not 100% okay in your last attachment. It looks like there are degenerated blocks near the sharp angle. But this could also be a matter of perspective.
Why don't you share your project? Would be much easier. |
May 8, 2014, 09:55 |
#13 | |
Daniel
Rep Power: 21 |
Now I am uploading the project on a another host. |
May 8, 2014, 10:01 |
#14 | |
Daniel
Rep Power: 21 |
http://www.rodfile.com/r86znlonj5zq Last edited by Daniel_Khazaei; May 8, 2014 at 15:29. |
May 8, 2014, 12:22 |
#15 |
Javi
Rep Power: 16 |
What is the password?
May 8, 2014, 14:19 |
#16 |
Rep Power: 24 |
After having a look at your project I must admit that our suggested blocking strategy is probably wrong. You can do it, but you will end up with some bad elements and run into trouble with ogrid creation (see att which is without ogrids).
Meanwhile I think I have understood the strategy in your posted pics. I will explain this later/tomorrow as I am going home now. |
May 8, 2014, 15:44 |
#17 | |
Daniel
Rep Power: 21 |
I am eagerly waiting to hear from you. |
May 9, 2014, 09:44 |
#18 |
Rep Power: 24 |
I have attached the generic blocking structure for your geometry. Now you have to apply to your geometry. If possible I would strongly suggest a geometry clean up in CAD. I tried it myself in Designmodeler. It somehow worked but destroyed the surface structure.
If blocking is to hard you can also try ANSYS Workbench CutCell meshing. I just started to work with it this week and it gave decent results in a short time. It is really not hard to handle if you are familiar with other meshing tools. |
May 9, 2014, 09:47 |
#19 |
Rep Power: 24 |
Blocking attached. The .blk* (e.g. .blk3) show the progress of work.
May 9, 2014, 09:56 |
#20 | ||
Daniel
Rep Power: 21 |
I will try to work this out. |
Display Modes | |
[ICEM] Hexa meshing of impeller and diffuser assembly | Nitin Dewangan | ANSYS Meshing & Geometry | 14 | September 13, 2016 10:41 |
[ICEM] Hexa dominant meshing | Pat84 | ANSYS Meshing & Geometry | 19 | December 2, 2015 18:20 |
Wind tunnel hexa meshing in ICEM CFD 12.1 | matheusguzella | ANSYS Meshing & Geometry | 1 | March 14, 2011 17:14 |
Hexa Block meshes in ANSYS Meshing? | siw | ANSYS Meshing & Geometry | 3 | July 31, 2009 11:40 |
Hexa meshing or Tetra meshing??? | NITIN DEWANGAN | CFX | 5 | August 5, 2008 10:59 |
