May 13, 2014, 13:37 |
Heat Exchanger
Engineer
When creating baffles mesh gets distorted. How to mesh the inner pipe with baffles ?
Blocking strategies for inner pipe. Pipe should not be removed. Thanks in advance |
May 14, 2014, 04:09 |
Raghav
share me your geometry. will work out.
May 14, 2014, 13:25 |
Heat Exchanger Geometry
Engineer
I have attached the Heat Exchanger geometry. Please have a look.
May 19, 2014, 01:19 |
Raghav
Please find below the blocking files for your geometry..
May 19, 2014, 02:26 |
Praveen Kumar R
Rep Power: 12 |
Hi Prashant,
You have done the blocking for the outer tube correctly. But you need one more O-grid to resolve the inner tube of heat exchanger (Similar to concentric tubes) and put these innermost blocks in a separate part in ICEM. Not in the same part (FLUID) as that of the outer block. Its good you have used face interpolation to resolve baffles. One more suggestion. It is always good to create the boundary layer O-grid at last, after resolving all the geometry parts. If I am not wrong, you are working on the assignment from the ICEM course of LearnCAx . I really appreciate your efforts in completing the task. Although it is a test or assignment, you can take help of our technical support team at any moment of your learning. We will be more than happy to help you in this regard. Happy Learning !!! Praveen Kumar R |
May 19, 2014, 05:08 |
Heat_Exchanger with Baffles
Raghav
FYR..
Have placed the ICEM files in 2 separate zip files. Roughly I gave mesh parameters. You can add BLs as per your requirement. Regards, Raghav |
How to carry out 3D shell and Tube Heat Exchanger analysis in fluent | medogalal | FLUENT | 3 | December 30, 2015 04:28 |
Question about heat transfer coefficient setting for CFX | Anna Tian | CFX | 1 | June 16, 2013 06:28 |
Macro Heat Exchanger not selecting (Please help!) | zdeth | FLUENT | 2 | September 11, 2012 13:52 |
UDF for Heat Exchanger model | francois louw | FLUENT | 2 | July 16, 2010 02:21 |
