Home > Forums > ANSYS Meshing & Geometry
[ANSYS Meshing] unvocered faces ICEM
Old   May 15, 2014, 09:36
Default unvocered faces ICEM
manymen is on a distinguished road
Hello guys,
I know that this is not a new problem but I really don't know how to fix it in my case.
I have uncovered faces in a diffuser between a normal and o-grid block. In pre-mesh everything looks good. When i export the mesh into Fluent i get an error "Aborted due to critical error". I think i have a problem with the associations. My o-grid ends in the splitted face.
Please look at the pictures, that I have uploaded.
I tried so many thinks, please can anyone help me?
manymen is offline   Reply With Quote
Old   May 15, 2014, 19:56
kad
kad will become famous soon enoughkad will become famous soon enough
You can not have a normal block right next to the ogrid block. They have different structures. In general blocking in ICEM produces a structured mesh. This structure propagates through the whole blocking domain. In your case the structure is destroyed at the intersection which then leads to uncovered faces. Check the tutorial manual. There is a tutorial for meshing a duct going from circle to square shape.
kad is offline   Reply With Quote
Old   May 16, 2014, 06:32
Ion
JohnnyB is on a distinguished road
Did you try to associate a face from that block to the near surface?
JohnnyB is offline   Reply With Quote
Old   May 16, 2014, 10:46
Thumbs up
Hello guys,
thanks for helping!
As I have done the ogird, there was a transition block between the ogird and the normal block. I deleted this block and moved the o-grid-verices in the plane of the block, because I wanted to improve the mesh quality (stupid)
Now, I have created a similar block (see picture newblock) and tried to associate this with the other blocks. All without success.
@JohnnyB: Yes I tried to assocciate the near Faces with the Surface. I tried the Method Closest Interpolate, without success. I uploaded a picture.
Does anyone have any ideas how to fix this problem? Thanks
Old   May 17, 2014, 08:51
Ion
Can you split this domain in two? Than you can easily generate a mesh for this two domains with an interface between.
Old   May 19, 2014, 07:41
kad
The blocking structure is still not correct. The outer ogrid blocks are not connected to any other blocks in -x direction.
Thread Tools
Trackbacks are On
[ANSYS Meshing] How to deal with the added faces produced in ANSYS ICEM CFD mesh? rockzh ANSYS Meshing & Geometry 4 October 17, 2014 14:48
AMI speed performance danny123 OpenFOAM 19 October 24, 2012 07:44
snappyHexMesh won't work - zeros everywhere! sc298 OpenFOAM Native Meshers: snappyHexMesh and Others 2 March 27, 2011 21:11
external flow with snappyHexMesh chelvistero OpenFOAM 11 January 15, 2010 20:43
BlockMeshmergePatchPairs hjasak OpenFOAM Native Meshers: blockMesh 11 August 15, 2008 07:36
