May 15, 2014, 22:35 |
Skewness on the higher side
Abhijith Mohan
Rep Power: 12 |
hi, am NEW TO ansys fluent 14. I am doing a simulation on a counter flow heat exchanger. I am getting the shadow walls and conduction occurs across the wall while am giving a coarse mesh. But when i make the mesh finer my solution is no t getting converged. On iterating sometimes it shows "temprature limited to .... (some value)" and iteration goes on .. when I checked the quality of the mesh i found that Skewness and orthogonal quality is out of the allowable limits. How can i correct this?
Thanks in advance |
May 16, 2014, 14:09 |
Engineer
Rep Power: 13 |
Hallo Abhijith, did you mesh your geometry using Ansys Meshing or ICEM CFD ? Check the locations of bad skewness and orthogonal angle. Perform some local mesh refinements. If possible share your geometry, I can have a look .
May 18, 2014, 02:20 |
meshing
Abhijith Mohan
Rep Power: 12 |
Thankyou Prashanth for replying . I am using ICEM CFD. I have attached the geometry please have a look. I the mean time I l try to do the local refinements as you said.
May 20, 2014, 06:50 |
problem solved
Abhijith Mohan
Rep Power: 12 |
thankyou Prshanth .
i was able to solve the problem |
Error finding variable "THERMX" | sunilpatil | CFX | 8 | April 26, 2013 07:00 |
[blockMesh] BlockMeshmergePatchPairs | hjasak | OpenFOAM Meshing & Mesh Conversion | 11 | August 15, 2008 07:36 |
CFX Solver Memory Error | mike | CFX | 1 | March 19, 2008 07:22 |
Severe nonorthogonality and severe skewness problem | qtian | OpenFOAM Running, Solving & CFD | 2 | January 22, 2008 18:47 |
[Commercial meshers] Converting meshes that includes interfaces | ham | OpenFOAM Meshing & Mesh Conversion | 29 | January 8, 2007 08:58 |
