[GAMBIT] unable to mesh after a volume subtraction operation
Old   May 21, 2014, 04:34
Default unable to mesh after a volume subtraction operation
mahmood
sakil2k3 is on a distinguished road
I am doing a mesh of a square box (Volume 1-solid) having channel inside (Volume 2-Fluid). The channel have several right angel turns inside the box.
I used GAMBIT 2.4.6 for meshing and I subtract Vol 1 to vol 2 and retain vol 2. Every thing is ok but when I try to mesh (HEX with submap) it says: Assertion failed in BppLongprt.cc line 20:0 while meshing volume 1.
Why it happens can any one explain??? How can I mesh?
sakil2k3 is offline   Reply With Quote
Old   May 23, 2014, 03:07
-mAx-'s Avatar
Maxime Perelli
-mAx- will become famous soon enough
can you please display your geometry?
In memory of my friend Hervé: CFD engineer & freerider
-mAx- is offline   Reply With Quote
Old   May 23, 2014, 11:24
mahmood
The image link is:
https://mega.co.nz/#!gU5zVYAJ!nNmgvM...TrWWa5mQvkNB6g
I can mesh the channel volume. But the solid volume can not be meshed in hex..
can you suggest any thing?
Old   May 26, 2014, 06:10
-mAx-'s Avatar
Maxime Perelli
I cannot see your picture.
Moving mesh Niklas Wikstrom (Wikstrom) OpenFOAM Running, Solving & CFD 122 June 15, 2014 06:20
[blockMesh] non-orthogonal faces and incorrect orientation? nennbs OpenFOAM Meshing & Mesh Conversion 7 April 17, 2013 05:42
[Gmsh] 2D Mesh Generation Tutorial for GMSH aeroslacker OpenFOAM Meshing & Mesh Conversion 12 January 19, 2012 03:52
[snappyHexMesh] snappyHexMesh won't work - zeros everywhere! sc298 OpenFOAM Meshing & Mesh Conversion 2 March 27, 2011 21:11
How to control Minximum mesh space? hung FLUENT 7 April 18, 2005 09:38
