May 22, 2014, 07:32 |
circle inside a rectangle
Rep Power: 12 |
Hi
PFA the surface to be meshed. Iam unable to mesh this splitted surface. Can any body resolve this? |
May 23, 2014, 03:06 |
Maxime Perelli
Rep Power: 41 |
what do you want to do (exactly)?
for sure you will have problem with tangential line to top/bottom circle
In memory of my friend Hervé: CFD engineer & freerider |
May 23, 2014, 08:44 |
Rep Power: 12 |
Hi Max,
Thanx for the reply. I want to mesh the small surfaces around the circle. |
May 26, 2014, 06:09 |
Maxime Perelli
Rep Power: 41 |
I don't think it is the right method for doing it in this way.
Again what are you trying to do? Why did you split your geometry in this way?
May 26, 2014, 11:39 |
circle in a rectangle
Rep Power: 12 |
Hi Max,
Thanks for your response. I got the solution for this problem.As you said I need not split it. Thank you once again. |
[snappyHexMesh] meshing inside a circle | rade1010 | OpenFOAM Meshing & Mesh Conversion | 2 | September 10, 2012 00:41 |
[ICEM] Bocking Strategy Suggestions for 2d Trefoil Shape Inside Rectangle | mullzer | ANSYS Meshing & Geometry | 2 | March 2, 2012 14:06 |
[Other] Defining a circle within a rectangle domain | amscosta | OpenFOAM Meshing & Mesh Conversion | 1 | August 14, 2009 15:03 |
OpenFOAM on MinGW crosscompiler hosted on Linux | allenzhao | OpenFOAM Installation | 127 | January 30, 2009 19:08 |
meshing F1 front wing | Steve | FLUENT | 0 | April 17, 2003 12:37 |
