[ANSYS Meshing] Error in making hexahedral mesh
Old   May 27, 2014, 01:39
Default Error in making hexahedral mesh
george
gorge is on a distinguished road
I have a geometry of a cuboid with a cavity in it. Inside the cavity there is another smaller cuboid. I need to create a hexahedral mesh for the entire object. I used the multizone method. During the source and target face selection I am unable to select the faces of the object inside the cavity. Also an error is cropping up if I just select the outside block-
ERROR - MultiZone found free block in swept body.
Pls suggest.
gorge is offline   Reply With Quote
cfx, meshing, multizone
3D Hybrid Mesh Errors DarrenC ANSYS Meshing & Geometry 11 August 5, 2013 06:42
[snappyHexMesh] Layers:problem with curvature giulio.topazio OpenFOAM Meshing & Mesh Conversion 10 August 22, 2012 09:03
friction forces icoFoam ofslcm OpenFOAM 3 April 7, 2012 10:57
