Home > Forums > ANSYS Meshing & Geometry
[ICEM] Heat exchanger unstructured mesh
Old   June 9, 2014, 15:58
Question Heat exchanger unstructured mesh
TheoK is on a distinguished road
Hello all and sorry for the long post. I am currently an undergraduate student, new to CFD, trying to finish his thesis. That requires meshing the model in ICEM and simulating an air to air cross flow heat exchanger with 10 cylinders (9 interior cylinders and 1 exterior (adiabatic)), each one inside another in FLUENT.
I am using the volume and part meshing (octree), so I get a mesh with 10 solid volume meshes (for the cylinders) and 10 fluid volume meshes (for the air). My question is, should I delete the solid volume meshes, and how can I generate a thermal resistance in their place?
Also should I create a single part for the fluid volume mesh (cause it's all air), or should I keep two different streams (hot & cold)?
I am asking all these, cause I'm trying to simulate it in FLUENT, and if I don't combine the fluid volumes into 1 part, the program splits the surfaces into 2 parts (for example: wall-1 and wall-1:0.05).
Thanks in advance
TheoK is offline   Reply With Quote
Thread Tools
Trackbacks are On
Concentric tube heat exchanger (Air-Water) Young CFX 5 October 6, 2008 23:17
shell and tubes heat exchanger mesh antonio FLUENT 2 January 15, 2006 11:30
How to control Minximum mesh space? hung FLUENT 7 April 18, 2005 09:38
Gambit problems Althea FLUENT 21 February 6, 2001 08:05
