[DesignModeler] Conversion of imported points
Old   June 19, 2014, 04:54
Default Conversion of imported points
Arnoult
Guiz is on a distinguished road
Hello everyone,
I have some issues with DesignModeler.
I had imported a file of points from coordinates in DesignModeler. Now I want to convert all the points into sketching but I don't know how to do it.
Is it possible to convert imported points?
Thank you in advance
Guiz
Guiz is offline   Reply With Quote
Old   June 26, 2014, 10:47
Diogo Rebelo
bafalle is on a distinguished road
I have the same problem! I want to import several points and lines from .txt but I need it for a User Defined Section. Actually I need to do this for almost 70 sections..
bafalle is offline   Reply With Quote
[snappyHexMesh] .STL: non-closed manifold surface giulio.topazio OpenFOAM Meshing & Mesh Conversion 32 November 25, 2016 03:15
[snappyHexMesh] No layers in a small gap bobburnquist OpenFOAM Meshing & Mesh Conversion 6 August 26, 2015 09:38
using METIS functions in fortran dokeun Main CFD Forum 7 January 29, 2013 04:06
[DesignModeler] DM's JScript: FPoint()'s GetPoint(i) function picks points backwards? ANT ANSYS Meshing & Geometry 2 July 23, 2012 15:25
[blockMesh] BlockMeshmergePatchPairs hjasak OpenFOAM Meshing & Mesh Conversion 11 August 15, 2008 07:36
