July 8, 2014, 15:38 |
Meshing a Wake
Eric
Rep Power: 11 |
I'm trying to model heat transfer from a heat sink using Fluent. I have a small part representing a heat source attached to a heat sink. Each is a separate part. I want to apply heat generation to the heat source and then model flow over the assembly. I'd like to generate a mesh with a refined region in the wake of the heat sink. I have been trying to do this using the body of influence method to control the element size around the heat sink. However, when I create a body around the sink and within the fluid domain, it creates a hole in my fluid domain and I can't seem to get a mesh in the wake. I have been creating all bodies as frozen bodies thus far and then forming a part from the bodies. This does not seem to be working though. Am I making a mistake when creating the geometry? How should I go about meshing the wake? |
July 9, 2014, 07:53 |
Błażej Popławski
Rep Power: 12 |
Switch off a Shared Topology Method in DM. It's in a Body or Part Details.
July 9, 2014, 08:16 |
Eric
Rep Power: 11 |
Thanks a lot that worked great!
July 9, 2014, 09:11 |
Eric
Rep Power: 11 |
Blazej,
I got the meshing to work, but I can't get a conformal mesh between my fluid and solid bodies. I need this because I want to simulate the heat transfer between the bodies. I changed the shared topology method in the details of my part to none. |
July 9, 2014, 11:35 |
Błażej Popławski
Rep Power: 12 |
Set Shared Topology Method to Automatic for your Part, switch it to None only for a body which will be your Body of Influence.
[ANSYS Meshing] Migrating from GAMBIT to ANSYS Meshing | David-CFD | ANSYS Meshing & Geometry | 1 | April 1, 2011 05:22 |
Meshing locks workbench window. | andy2o | CFX | 0 | February 1, 2008 05:01 |
Singularity of grid?Volume meshing vs face meshing | Ken | Main CFD Forum | 0 | September 4, 2003 11:09 |
Volume Meshing & Face Meshing? singularity of grid | ken | FLUENT | 0 | September 4, 2003 11:08 |
