[ICEM] Periodicity for wind turbine
Old   July 18, 2014, 08:26
Default Periodicity for wind turbine
Raj
RajG is on a distinguished road
I selected entire model (360 degree) of vertical axis wind turbine with 4 (rectangular) blades are on the rotor for analysis.
I want to give rotational periodicity for rotor to rotate 360 degree . I tried vector and base,axis,angle options in Rotational periodicity using icem cfd.
Please help me.
RajG is offline   Reply With Quote
Old   July 18, 2014, 09:08
Far
Sijal
Far has a spectacular aura aboutFar has a spectacular aura about
Send a message via Skype™ to Far
with all four blades, you dont need rotational periodicity
Far is offline   Reply With Quote
Old   July 19, 2014, 00:26
Raj
you mean,If we import mesh file in fluent without periodicity ,we can set rotor of wind turbine as rotating rotationally ?
Old   July 19, 2014, 03:44
Far
Sijal
Periodicity is different as compared to rotation settings in Fluent.
For example if you have three blades and you want to solve only one blade, now you have to use periodicity condition...
In any case whether one, two or all blades, you can set rotating condition in Fluent and not in ICEM
Old   July 21, 2014, 03:06
Raj
Thanks Sijal
Problem with torque output from a turbine simulation. pa-dundas FLUENT 5 July 17, 2022 05:27
Air Flow Analysis around a Wind Turbine NightHawkRaven FLUENT 4 August 12, 2014 17:18
Boundary condition setting regarding turbine simulation using CFX Lacerlacer CFX 11 March 12, 2012 09:32
radial inflow turbine rotor periodicity problem Nanda FLUENT 1 July 17, 2006 14:52
radial inflow turbine rotor periodicity problem Nanda FLUENT 0 July 11, 2006 20:35
