[ICEM] ICEM CFD error when running in batch mode
Old   August 14, 2014, 13:45
Default ICEM CFD error when running in batch mode
Daniel B
bgp723 is on a distinguished road
I am running ICEM CFD 14.5 using matlab.
I create a ICEM CFD replay script using matlab with the command
eval(['! icemcfd -batch -script ' MyDir '/GeoMeshScript.rpl']), which allows me to execute ICEMCFD.
Everytime I use batch mode, I get this error message everytime:
Usage split_grid node dim val [ dim:min,max ] [ m m1 m2 ... ] [ marked ]
while executing
"hexlib_interface__574 split_grid 21 25 GEOM.74 m GEOM GEOM_FLUID SOLID FLUID INLET OUTLET INT-PRESS-IN INT-PRESS-OUT CONTACT-REGION SYM-INLET SYM-OUTL..."
("eval" body line 1)
invoked from within
"eval $hexlib split_grid $args"
(procedure "ic_hex_split_grid" line 15)
invoked from within
"ic_hex_split_grid 21 25 GEOM.74 m GEOM GEOM_FLUID SOLID FLUID INLET OUTLET INT-PRESS-IN INT-PRESS-OUT CONTACT-REGION SYM-INLET SYM-OUTLET SYM-FIN SYM-..."
invoked from within
"batch_interp eval ic_hex_split_grid $args"
However, when I use interactive mode (basically change -batch to -interactive), so eval(['! icemcfd -interactive -script ' MyDir '/GeoMeshScript.rpl']),
the replay script works perfectly fine and creates the desired mesh.
I would prefer to run everything in batch instead of interactive mode because batch allows faster processing.
Please someone help me figure out this issue
Thank you
bgp723 is offline   Reply With Quote
to run a replayfile in batch mode from UNIX froztbear ANSYS Meshing & Geometry 4 May 13, 2014 08:00
force to wait MATLAB for running parallel fluent in batch mode a.latifi Main CFD Forum 1 May 9, 2013 16:44
ICEM CFD use for ? Vu Trinh Tuan CFX 14 April 11, 2011 18:38
What do you CFD guys do during a long simulation running? bearcat Main CFD Forum 5 July 23, 2009 08:08
ICEM CFD 5.1 Hex-Tet mesh merging failure bogesz CFX 1 January 29, 2005 06:46
