May 30, 2009, 06:23 |
meshing of turbine blade
jay
Rep Power: 16 |
hi,
I want to learn turbo machines analysis in GAMBIT and Fluent..... Anyone who have experience of CFD please help me.... please give me if u have any tutorials (apart from given within softwares).... I am working for my masters thesis on effect of stagger angle on turbine blade cascade. Thank you. |
May 30, 2009, 06:33 |
tutorials of turbine blades
HI,
Give me your mail ID i should send,actually i have pdf format All the best.
sivaramakrihnaiah |
May 30, 2009, 13:10 |
There are two ways of doing this.
1. using Template for turbomachinery i.e. G turbo. This is the easiest way with minimal user input 2. Manual method Now tell me whichmethod you like. |
May 30, 2009, 13:45 |
@ sivaramakrihnaiah
jay
Rep Power: 16 |
@ sivaramakrihnaiah
Thanks for reply. my e mail id is jaydeeptrivedi03ae47@yahoo.com |
May 30, 2009, 13:50 |
@ Far
jay
Rep Power: 16 |
Thanks for reply.
Does G turbo stands for Turbo tool in gambit. I would first like to go for easy method as I have less little experience in turbo meshing. Thank You. |
May 30, 2009, 14:16 |
You just have to convert the IGES file into turbo format i.e .tur . and then press some buttons in gambit. your file of turbine/compressor simulation is ready.
That is all you need in gambit and then run solution in fluent |
May 31, 2009, 01:07 |
@ Far
jay
Rep Power: 16 |
Thanks for reply.
I have done gambit tutorials related to turbo tool but since same tuto is not in fluent i am having problems... I dont know which boundary conditions r to be applied. I need some tutorial of turbo which guides through both gambit and fluent. some research papers r there but most of them requires subscription. do u have any tuto apart frm already given in software? |
May 31, 2009, 06:33 |
you need following boundary condtions
1. Total pressure , total temprature, flow inlet angles at inlet 2. Static pressure at outlet corresponding to required mass flow rate and you need to turn on the radial equilibrium option 3. Fluid speed equal to your rpm (set the rpm as low value and then gradualy increase to required level. 4. Casing is stationary 5. periodic conditions for periodic surfaces Flow setting 1. Initially 1st order and courant number 1 2. Flow solver coupled implicit (also named as density based in fluent 6.3 and latter) 3. initialize from inlet values Turbulence model 1. K epsilon 2. SA (I have worked extensively with SA and found to be very accurate) 3. SST |
June 10, 2009, 04:38 |
#9 |
toto
Rep Power: 16 |
September 3, 2009, 10:07 |
#10 |
kaka
September 3, 2009, 10:22 |
#11 |
hi what you want
sivaramakrihnaiah |
September 3, 2009, 10:44 |
#12 |
kaka
the pdf that I can learn how to mesh turbo machines
October 29, 2009, 13:39 |
#13 |
toupador
Rep Power: 16 |
November 9, 2009, 11:39 |
#14 |
Juan
Rep Power: 16 |
Hello sivaramakrihnaiah, could you send me the pdf? My e-mail: xenxoc@gmail.com
I´m going to make a windturbine meshing and I need learn about it. Thank you. |
November 9, 2009, 21:49 |
#15 |
teguh hady
Rep Power: 17 |
@ sivaramakrihnaiah
Can you send me the pdf?? I need it. Thxs here is my email: huget_teguh@ymail.com teguhtf |
November 10, 2009, 22:02 |
#16 |
Khaled
Rep Power: 17 |
November 13, 2009, 04:32 |
Turbine Tutorial
#17 |
sivaramakrihnaiah |
November 14, 2009, 14:40 |
#18 |
toupador
Rep Power: 16 |
think you for the file
November 22, 2009, 22:48 |
#19 |
Alberto
Rep Power: 16 |
I have to simulate something like this for the University and it can be useful for me.
Thanks in advice lopezflorenciano@gmail.com Last edited by Alberto1987; November 23, 2009 at 00:46. |
November 22, 2009, 22:55 |
#20 |
welcome,
All the best for your bright future. Are you from
sivaramakrihnaiah |
force acting on gas turbine blade.... | vvj | Main CFD Forum | 1 | March 3, 2010 01:04 |
Q: how to do a good meshing in turbine usin gambit | oscar | FLOW-3D | 1 | March 14, 2009 23:15 |
Question on blade meshing | Jeffrey | CFX | 0 | March 7, 2008 17:13 |
Flow study through Turbine Blade passage | Subrata | FLUENT | 1 | May 4, 2007 11:28 |
Meshing pitched blade turbine | Racheal | FLUENT | 0 | July 12, 2005 13:25 |
