[DesignModeler] Making a "body" from a sketched line |
August 2, 2014, 16:38 |
Rep Power: 11 |
Dear experts,
Assume I design a (two-dimensional) channel, and make a rectangle for the channel itself. I then go to "CONCEPT" and then "SURFACES FROM SKETCH" in order to creat a meshable body (i.e.- an object I can mesh) from the rectangle. The problem is as follows: I have a sketched line segment that I want to define as a "wall". Unfortunately, all my attempts to creat a meshable object from this line failed, and it seems like the only option I have is to define this wall by using a rectangle with very small width. So: Is there any option to create a meshable object from a sketched line ? Thanks in advance ! |
[Gmsh] Problem with Gmsh | nishant_hull | OpenFOAM Meshing & Mesh Conversion | 23 | August 5, 2015 02:09 |
Derivative of velocity and mean velocity | hiuluom | OpenFOAM Post-Processing | 1 | May 29, 2015 23:42 |
[Gmsh] boundaries with gmshToFoam | ouafa | OpenFOAM Meshing & Mesh Conversion | 7 | May 21, 2010 12:43 |
DecomposePar links against liblamso0 with OpenMPI | jens_klostermann | OpenFOAM Bugs | 11 | June 28, 2007 17:51 |
Problems of Duns Codes! | Martin J | Main CFD Forum | 8 | August 14, 2003 23:19 |
