August 6, 2014, 22:44 |
Structured Mesh on Complex Geometry
Zak
Hey Guys,
I having trouble getting my mesh to converge in Fluent. I have 1.6 Million nodes Determinant > 0.4 Min angle > 9 degrees Any suggestions I can make to the mesh? Thanks |
August 8, 2014, 07:48 |
Sebastian Engel
Rep Power: 20 |
Hi Zak,
the min angle of 9 degree might be low, try to get closer to 45. I also would improve the change rate of cell sizes. I marked the edges in your screenshots which might need some improvement. A small cell next to a relatively bigger cell can lead to numerical instabilities if high gradients are in this area (had this issue a while ago). I would try to make the change of cell sizes a bit smoother. And another question, why is the mesh inside the canule aligned with the pipe's surface? Do you need the solid mesh? meshcheck1.jpgmeshcheck2.jpg And what about the outlet, is it far enough downstream? |
Volume mesh for Cyclone separator | Rajan | Pointwise & Gridgen | 17 | May 4, 2014 05:38 |
[ANSYS Meshing] Meshing Strategy for inside geometry | powpow | ANSYS Meshing & Geometry | 6 | January 16, 2013 04:32 |
[Gmsh] 2D Mesh Generation Tutorial for GMSH | aeroslacker | OpenFOAM Meshing & Mesh Conversion | 12 | January 19, 2012 03:52 |
2d irregular grid | Remy | Main CFD Forum | 1 | December 22, 2008 04:49 |
unstructured vs. structured grids | Frank Muldoon | Main CFD Forum | 1 | January 5, 1999 10:09 |
