August 7, 2014, 03:05 |
circle creation
Govindaraju
Rep Power: 17 |
Dear all
Please find the attache picture Mesh 1 I would like to create a circle parallel to the bottom circle where I marked a line Mr Far has created for the same diagram in Mesh 2. I am trying to do the same method . Please help me to create a circle which is parallel to the bottom circle as shown in the figure 2 Thank you Govind |
August 7, 2014, 08:01 |
Rep Power: 24 |
You can copy the original circle to your desired location and then project its curves on surfaces.
August 7, 2014, 10:13 |
Govindaraju
Rep Power: 17 |
August 7, 2014, 10:55 |
Rep Power: 24 |
Use the tab "Transform Geometry" and -> "Translate geometry". Make sure to activate the "copy" option. Specify the coordinates for the new circle and apply.
This new circle won't probably fit onto your geometry so it must be projected. Use "Project curve on Surface" with method normal to surface or specify a direction. |
August 7, 2014, 12:11 |
#5 | |
Govindaraju
Rep Power: 17 |
Still I could not fix the curve . I did o grid blocking then I tried to draw a circle ( curve) But I could not arrive it Please find the mesh geometry . How to fix this problem |
Problem with circle sampling type, of Sample utility | nik | OpenFOAM Post-Processing | 4 | May 29, 2017 05:27 |
project circle on cylinder | Mohsin | FLUENT | 0 | August 29, 2010 21:59 |
Subtraction of a circle from a rectangle,Gambit | engahmed | ANSYS Meshing & Geometry | 2 | May 17, 2010 01:08 |
Find perpendicular intersection bet. pt & circle | zonexo | Main CFD Forum | 3 | July 27, 2007 08:53 |
How to mesh a circle by Gambit? | Zhengcai Ye | FLUENT | 5 | March 24, 2006 01:04 |
