[ICEM] Method Of Meshing
Old   August 18, 2014, 05:08
Default Method Of Meshing
Stephen Summerhayes
Summerhayes is on a distinguished road
I've been using fluent for some time now, and am attempting to simulate a rotating brake disc in airflow.
I've managed fine up until now, I have been optimising my disc and have some complex geometries that ansys mesher cant seem to mesh without having some high skewness cells.
I am thinking of using ICEM but am wary that it is a very steep learning curve and my geometry is complicated.
The geometry itself cannot be filleted or altered to remove small material areas or small angles as Solidworks cant fillet the surfaces as they are.
Is it feasible to create a mesh for this geometry, (including a rotating enclosure, with a bigger stationary air flow enclosure) using ICEM or are there other packages which are more automated but give options that ansys mesher.
If so could you recommend any techniques to best mesh this geometry?
As I'm new to ICEM I have very little knowledge on the way it works.
Ive attached an image of my disc and another of it inside its enclosures so you have an idea of what I'm dealing with.
Thanks
Steve
Summerhayes is offline   Reply With Quote
[ICEM] problem with meshing in icem cfd saurabhjoshi2011 ANSYS Meshing & Geometry 13 March 12, 2013 11:27
Immersed boundary method (IBM) vs Dynamic meshing tomyangbath Main CFD Forum 5 April 17, 2009 03:02
Urgent help, help pl for meshing problem Shashi FLUENT 8 October 8, 2008 11:24
Best Meshing scheme for Cylinder Nutrex Main CFD Forum 4 July 29, 2008 11:03
Panel method meshing programs Charles Main CFD Forum 3 March 24, 2007 13:54
