August 10, 2014, 09:40 |
Y block
Govindaraju
Rep Power: 17 |
Kindly help me to finish the O grid blocking I am very new to ICEM CFD user
Need to finish my project Govind |
August 10, 2014, 12:13 |
#2 | |
Govindaraju
Rep Power: 17 |
I have been trying this for two days . Please help me to fix the problem https://www.dropbox.com/s/mekeivwdev...CFD%20MESH.rar Thank you |
August 10, 2014, 20:20 |
#3 | |
Ovi
Rep Power: 13 |
It seems like you're on the right track from the attached image. Are you trying to create a Y-block in the intersection to achieve a fully hexahedral mesh? Best wishes.
-- Mechanical Engineering Sydney, Australia |
August 10, 2014, 21:40 |
#4 | |
Govindaraju
Rep Power: 17 |
That is why I am struggling How to do Y block This is my basic question? |
August 11, 2014, 22:40 |
Ovi
Rep Power: 13 |
This is a basic outline -
a) Toolbar - Blocking>Edit Block>Modify Block Type b) Set the drop-down menu "Set Type" to Y-block and select the one at the junction. Additionally, there is an option to select the faces you want to exclude from this operation just below the drop-down menu. Hope this helps.
August 12, 2014, 00:40 |
#6 | |
Govindaraju
Rep Power: 17 |
Thank you for your kind help Please find the attached geometry . . Is the blocking correct? is the quality of mesh is fine or low? I am not sure . Kindly help Thank you |
August 12, 2014, 04:18 |
Ovi
Rep Power: 13 |
Well yes it looks like you made the Y-block correctly and the splits also extend to the adjacent blocks, which is a good feature to have for sizing along the edges and to ensure that the blocks conform to each other.
Overall the mesh looks fine and you should be able to use metrics such as volume ratios/expansion ratios, aspect ratios, ortho. quality to determine the overall quality of the mesh. This falls under fairly fundamental knowledge of meshing and hence, there are plenty of resources out there to help. Additionally, I would check that central part of the Y-block since I have a feeling your solver may have problems with that. Try to reduce the skewness and ensure that you check the sizing bias or growth rates along the edges. Best wishes,
[blockMesh] Mixer mesh - negative volume problem | jadtwo | OpenFOAM Meshing & Mesh Conversion | 2 | November 6, 2014 16:37 |
T-Rex block next to structured block | Aeronautics El. K. | Pointwise & Gridgen | 7 | August 10, 2014 07:42 |
foamLog not solving for Ux, Uy, Uz | aerospain | OpenFOAM Post-Processing | 5 | April 18, 2012 10:01 |
[Commercial meshers] Icem Mesh to Foam | jphandrigan | OpenFOAM Meshing & Mesh Conversion | 4 | March 9, 2010 02:58 |
blockMesh: block with 6 vertexes | dani | OpenFOAM | 3 | June 25, 2009 13:13 |
