Home > Forums > ANSYS Meshing & Geometry
[ICEM] Mesh patches
Old   August 16, 2014, 06:47
Default Mesh patches
Govindaraju
kmgraju is on a distinguished road
hai
please check the attached geometry when i import mesh geometry created in ICEM CFD to CFX for analysis, I found some patches. How do I rectify it. wHEN i RUN THE SIMULATION i FACE THIS PROBLEM
Thank you
kmgraju is offline   Reply With Quote
Old   August 21, 2014, 09:00
Govindaraju
Dear All
Please find the mesh file . I could not create quality mesh . The cfx solver comes with error. There are bad elements present. I am very new to this software. if you people guide me I can finish my work earlier
https://www.dropbox.com/s/gipygarswd...arify.zip?dl=0
Thank you
Old   August 22, 2014, 03:08
Govindaraju
Dear all
Any guidance to complete the mesh
Thank you
Old   August 22, 2014, 07:37
Sebastian Engel
bluebase is on a distinguished road
Hello kmgraju,
inside the pipe ends you created an ogrid to get better element qualities. That's good practice.
But the ogrid doesn't follow into the Y-Block-Section. You should create the Y-Block before generating the ogrid in the whole volume.
The way you have done it (probalby alle pipe ends seperately) is not a good way as you noticed. You need to find a way to generate the ogrid in "one run". Play around with the selections! I would start by selecting all blocks and the faces of the inlet and outlet boundaries.
It might be possible to start with seperate ogrid, but it's more complex, one has to select the right faces
After you created your ogrids, you moved or even merged vertices to positions where neighboring blocks were degenerated to triangular blocks or blocks without any volume. Numerically they are still there! And these blocks are the main source of your problems.
Try to avoid by all means fitting a hexa block into a triangular shape (cases with wedge elements needed are rare). Numerically the contained elements stay hexas, even if the graphic output looks different. Simply spoken, no solver will give you a meaningfull result with degenerated elements or negative volume elements.
Another tip, use the quality checks! A simple rule, the determinant of the premesh must be all positive. Check for Elements with negative determinant and determinant close to 0.
Check out the help and tutorials for the features "Index Control", "Scan planes". They help a lot to find flaws in a blocking.
I hope you get some new ideas to improve your mesh =)
With regards,
Sebastian
bluebase is offline   Reply With Quote
Old   August 22, 2014, 08:29
Govindaraju
Originally Posted by bluebase View Post
Hello kmgraju,
With regards,
Sebastian
Dear Sebastian
Thank you for your guidance . I will try but I am very new to this software. I am learning myself without any other people help. Only help I can get from this forum
Thank you
Thread Tools
Trackbacks are On
Foam::error::PrintStack almir OpenFOAM Running, Solving & CFD 62 June 16, 2016 03:01
[ICEM] surface mesh merging problem everest ANSYS Meshing & Geometry 44 April 14, 2016 06:41
[ICEM] Orthogonality/Skew issues in 3D unstructured mesh eddyy19g ANSYS Meshing & Geometry 3 February 13, 2014 10:36
[ICEM] Problem making structured mesh on a surface froztbear ANSYS Meshing & Geometry 4 November 10, 2011 09:52
external flow with snappyHexMesh chelvistero OpenFOAM 11 January 15, 2010 20:43
