August 25, 2014, 17:04 |
Icem cfd 14.5
Camilo
Well, I'm trying to do a mesh and after the "compute" ends, appears a sign that say's "Your geometry has a hole, do you want to repair it?" I'm working on my final undergraduate project, it is a hovercraft, so, I guess that obviously it should has a hole.
So, the options for the sign are: Yes, No or Only shells. Yes: appears yellow, green and red lines arround the bottom of the hovercraft. No: I used the "check messh" and about 8% appears a sign of "diagnostic: uncovered" appears a number and "problem elements were found. You can put them in a new subset 'uncovered faces', fix the problem by covering the exposed faces, or ignore." whatever I do, again appears another and another problem. So... I'm kind of lost... and I would really appreciate some help |
[ICEM] Icem CFD on Linux | mechanicaldesign | ANSYS Meshing & Geometry | 7 | March 11, 2021 19:44 |
Need help icem cfd | kakhtar | ANSYS Meshing & Geometry | 25 | January 31, 2017 01:09 |
Transport mesh from ICEM CFD, to Fluent, to Sysnoise | Wieland | FLUENT | 2 | April 15, 2012 06:28 |
Importing Solidworks part into ICEM CFD | MetalSupremacist | FLUENT | 0 | October 8, 2010 17:46 |
Which is better to develop in-house CFD code or to buy a available CFD package. | Tareq Al-shaalan | Main CFD Forum | 10 | June 12, 1999 23:27 |
