August 6, 2014, 16:19 |
Solid mesh with no prism layers
Roberto Meloni
Rep Power: 13 |
Hi.
I'm meshing a complex geometry of a gas turbine combustor using ICEM. The mesh is composed by both the fluid and the solid parts. I made the tetra mesh for the entire model (fluid and solid) but when I go to build the prism layers the latter are added also at the solid mesh (see the simplified figure in attach). I defined the parameters of the prism layer at the surface that is the interface between the solid and fluid region, but I want that the solid wall doesn't contain the prism layers!!! How can I fix this issue? thank you in advance for your time and consideration. Best regards. |
August 7, 2014, 07:55 |
Rep Power: 24 |
In the menu for selecting prism parts activate the volume part "fluid" as well. Check the ICEM manual for "compute prism mesh".
August 8, 2014, 02:42 |
Roberto Meloni
Rep Power: 13 |
Hi...and thank you very much for your rep
ly. So, Have I to check both surface and fluid volume? It seems quite redundant! All the best. Roberto |
August 8, 2014, 07:47 |
Rep Power: 15 |
You must put the check mark also to the part name of the volume mesh of the fluid side, and solid side must be unchecked. Marking none of the volumes will result in prisms in all of the volume parts that is adjacent to the marked surface.
August 8, 2014, 11:37 |
Roberto Meloni
Rep Power: 13 |
Thank you guys for your help.
Unfortunately, the problem is not solved yet. Firstly, I create a tetra mesh, obtaining different domains (two solid walls and three fluid domains). Now, I want to create the prism layers at the wall. When I'am going to create the prism layers, have I to click on "Replace" or "Merge"? If I click on merge other domains overlap the previous ones. Do you suggest to create simultaneously the tetra and the prism layers? |
September 10, 2014, 11:42 |
Lorenzo Mazzei
Rep Power: 15 |
I have made a quick test and it does not work also in my case... The prisms are generated in both directions.
September 11, 2014, 08:55 |
Rep Power: 15 |
September 11, 2014, 09:38 |
Lorenzo Mazzei
Rep Power: 15 |
Actually now it works! A colleague of mine had created two bodies with the same name for the two solid volumes, but giving different names it has been fixed.
prism layers, solid air interface, solid mesh |
Display Modes | |
[snappyHexMesh] No layers in a small gap | bobburnquist | OpenFOAM Meshing & Mesh Conversion | 6 | August 26, 2015 09:38 |
[ICEM] Generating Mesh for STL Car in Windtunnel Simulation | tommymoose | ANSYS Meshing & Geometry | 48 | April 15, 2013 04:24 |
[ICEM] Tetra mesh quality before and after prism layer | Chander | ANSYS Meshing & Geometry | 0 | December 25, 2011 22:04 |
Getting prism to inflate into mixed tet-hex meshes | Joe | CFX | 16 | October 10, 2011 07:06 |
How to control Minximum mesh space? | hung | FLUENT | 7 | April 18, 2005 09:38 |
