[ANSYS Meshing] Two cylinder meshing
Like Tree2Likes
  • 2 Post By evcelica
Old   February 11, 2021, 11:07
Default Two cylinder meshing
Valaki Valami
woodwax is on a distinguished road
Hi, I dont have a much experience with meshing. I meshed these two cylinders.
The bottom of the cylinder will be on constant temperature. There will be small parts on the top off smaller cylinder. That is not completed yet.
I want to ask, is that a good way of meshing these cylinders for that simple experience? Is any way to improve it? There are some strange cross lines in section plane view, is that normal?
woodwax is offline   Reply With Quote
Old   February 11, 2021, 11:31
Erik
evcelica is on a distinguished road
Ignore the strange lines, I don't believe that is really part of the mesh, just graphical.
If this is just a solid, and not a fluid, that mesh is likely just fine. If it were fluid, I would have a smaller square or octagon in the middle, and mesh outward from there, so I didn't get those skewed elements in the 4 corners. But mesh quality for a solid is much less important, especially with just 1DOF (heat transfer).
woodwax and aero_head like this.
evcelica is offline   Reply With Quote
[ICEM] Meshing inclined cylinder with PBC tetra mesh ICEM shashi_soman ANSYS Meshing & Geometry 0 September 26, 2015 18:27
Meshing inclined cylinder with PBC tetra mesh ICEM shashi_soman Mesh Generation & Pre-Processing 1 September 26, 2015 18:05
[blockMesh] meshing a cylinder Nico A. OpenFOAM Meshing & Mesh Conversion 0 April 7, 2011 11:09
[snappyHexMesh] SnappyHexMesh Meshing inside a cylinder nammari OpenFOAM Meshing & Mesh Conversion 5 March 11, 2011 19:49
Best Meshing scheme for Cylinder Nutrex Main CFD Forum 4 July 29, 2008 11:03
