[ANSYS Meshing] meshing the 3d u-pipe in ansys |
May 24, 2016, 05:37 |
#21 |
Rep Power: 13 |
For sweep meshing the number of cells in the cross section of the thicker part and the thinner part will remain the same. hence it reduces the cell size to put in the same number of cells in the constriction. slice vertically before and after the constriction as well, then you will be able to simply sweep the two cylinders created without any slices. for the converging part err well try meshing it separately.
May 24, 2016, 16:33 |
#22 | |
Awais
Rep Power: 10 |
I tried that before (2 cylindrical bodies on either side and constriction in between). However, there were no other slices there to divide the cylinders. The issue there was that the mesh and inlet and outlet faces was not uniform(skewed) and at constriction I had unstructured mesh. I think you meant to say keep the slices that I showed in my last post and add two extra vertical slices? I actually thought of that after my post, but the issue that I am having there is with the constriction. As you can see that the cylinders are easily swept and the mesh in those regions is structured, but when it comes to the constriction, I am having a bit of an issue. a.JPG b.JPG What is happening here is that I am trying to create slices (with loft function) at the constriction but as you can see from the image below that vertices on two sketches are not being associated in correct way for some reason. Hence I can not create slices here and this in turn is causing poor quality in constriction and imposing bad quality in other regions as well. d.JPG c.JPG I think if I can associate the vertices correctly, that should fix the problem. Do you know if there is a way to fix this within workbench ? Thanks again for you help, I really appreciate this! Cheers! Awais |
May 24, 2016, 19:17 |
#23 |
Rep Power: 13 |
if you really want a structured mesh used ICEM,
but you can have a tet mesh at the constriction and a hex mesh elsewhere, a tet mesh with inflation layer is as good as a hex mesh in terms of the quality of the final results you will obtain. |
May 24, 2016, 20:04 |
#24 | |
Awais
Rep Power: 10 |
9
I have obtained a structured mesh within workbench. 1.JPG 2.JPG However, when I went on to inspect it, I found this butterfly like pattern 3.JPG Any idea what might be causing this? I think that this will significantly affect the solution. |
May 25, 2016, 19:13 |
#25 |
Rep Power: 13 |
when you do a cut section of a mesh, there is an icon in the same toolbar to display the whole of the cells, you are just cutting though the cells in a straight line and hence see this...
May 30, 2016, 12:45 |
#26 | |
Awais
Rep Power: 10 |
Thanks for your help throughout |
May 31, 2016, 08:52 |
#27 |
Rep Power: 18 |
June 27, 2016, 03:22 |
#28 | |
Omid Shekari
Rep Power: 9 |
When we "Form a new part" and put our slices in one part, doesn't it have any problem while analizing? I mean does Fluent simply understand the whole geometry is a single pipe and not 4 parts of flow beside one another? |
June 5, 2017, 14:39 |
Huge help! I had almost given up on this thing!
#29 |
Thanks a lot @Gweher. You guys are doing excellent work out here.
January 25, 2018, 01:03 |
#30 | |
DESMOND LIM CHIN YOONG
July 22, 2018, 01:41 |
Structured Meshing of 3D Pipe
#31 |
Udayraj Thorat
Rep Power: 7 |
Hello Everyone,
I am trying to simulate two phase flow in horizontal pipelines. I obtained structured meshing of Pipe using ICEM. However, I realised that I need to have two inlets instead of one at circular face of pipe and this is not possible in ICEM. So, Can anyone tell me how to do structured meshing of Pipe in workbench without using ICEM? Thank you, Regards |
July 22, 2018, 10:46 |
#32 | |
Rep Power: 18 |
MultiZone + Inflation + Mapped Face |
July 22, 2018, 12:27 |
#33 |
Udayraj Thorat
Rep Power: 7 |
Thank you so much
July 25, 2018, 07:56 |
Mesh Independence study of multiphase flow
#34 |
Udayraj Thorat
Rep Power: 7 |
I am doing numerical simulation of gas and liquid two phase flow through horizontal pipelines. What criteria should be chosen for the Mesh Independence study?
July 25, 2018, 10:41 |
#35 |
Rep Power: 18 |
July 26, 2018, 09:31 |
Meshing a cyclone separator
#36 |
Choose Country Then State
Rep Power: 7 |
Hi everyone.
I have difficulties in meshing a cyclone separator , I'm beginer in Ansys . Please can you explain me step by step |
June 17, 2021, 10:39 |
#37 |
Mouna
Rep Power: 4 |
is this procedure of meshing would be good if this tube will be considered qs a serpentine inside another rectangular fluid domaim.I'm wondering on the fact if the interface between the two regions would be affected because it is sliced.thanks
[ICEM] Simple pipe meshing - problems with y+ in CFX | Keizers | ANSYS Meshing & Geometry | 23 | January 15, 2015 08:00 |
[Workbench] Meshing for perforated pipe buried in porous zone | Tanjina | ANSYS Meshing & Geometry | 0 | September 24, 2014 09:41 |
Using ICEM CFD to repair/edit ANSYS Meshing | Kaaji1359 | ANSYS | 2 | July 30, 2013 10:28 |
[ANSYS Meshing] Migrating from GAMBIT to ANSYS Meshing | David-CFD | ANSYS Meshing & Geometry | 1 | April 1, 2011 05:22 |
[ANSYS Meshing] Ansys meshing with extended meshing | jsm | ANSYS Meshing & Geometry | 6 | January 10, 2011 12:09 |
