Home > Forums > ANSYS Meshing & Geometry
[ANSYS Meshing] meshing the 3d u-pipe in ansys
Like Tree4Likes
  • 1 Post By amin.z
  • 1 Post By Gweher
  • 2 Post By Gweher
Old   October 8, 2014, 12:45
Question meshing the 3d u-pipe in ansys
reza67 is on a distinguished road
hello everyones
i want to know what is the best way for meshing the 3d u-shape pipe in ansys
i'm begginer with ansys
plz explain me step by step
tnx a lot
reza67 is offline   Reply With Quote
Old   October 9, 2014, 20:23
hwet is on a distinguished road
whatever you do dont forget inflation, atleast 10 layers
hwet is offline   Reply With Quote
Old   October 10, 2014, 06:05
Gweher's Avatar
Gwenael H.
Gweher is on a distinguished road
Hello Reza,
Well you're question has already been treated in various topics but I will give you the useful links. I've explained, step by step, the meshing procedure with AM for a 2D U-bend geometry. In your case you need to apply a similar approach for your 3D, you will find here a thread regarding structured mesh in a 90 bend pipe.
Have fun
Gweher is offline   Reply With Quote
Old   October 12, 2014, 11:05
Originally Posted by Gweher View Post
Hello Reza,
Have fun
thanks Gweher
but i still couldn't find the best way to mesh my geometry
my geometry is a half u-tube like the picture shown below
could you help me ?
Old   October 12, 2014, 11:18
amin.z's Avatar
Amin
amin.z is on a distinguished road
Originally Posted by reza67 View Post
thanks Gweher
could you help me ?
Hey
Maybe using sweep could help you!
reza67 likes this.
Best regards,
Amin
amin.z is offline   Reply With Quote
Old   October 12, 2014, 14:23
Originally Posted by amin.z View Post
Hey
thanks amin
how can i decrease the mesh size in sweep method ?
what is the sweep element size ? line size? surface size ? volume size?
because it's scale is mm i think it should be line size but which line?
thanks again
Old   October 12, 2014, 15:52
amin.z's Avatar
Amin
thanks amin
thanks again
use this way:
first set a face size for one of the top faces of U tube
then use this setup:
mesh>insert>method
in geometry select the body
in method select sweep
in "src/trg selection" select "manual source and target"
in source select the face that apply face size
in target select another one face of top faces of tube
in "free face mesh type" choose "all quad"
and for "sweep num divs" enter an appropriate number! it's number of sweep layers!
I haven't experience in this shape but I guess this way should help you!
Good lock!
Best regards,
Amin
Old   October 20, 2014, 04:43
Gweher's Avatar
Gwenael H.
The method Amin described is the correct one. In my previous post I've mentioned a topic with 3D pipe where I explained the sweep method Amin described.
Originally Posted by Gweher; July 24, 2012, 17:36
For those who are curious, the problem was solved by selecting "manual source and target" under "sweep method" and specifying the source and target faces.
As it's nearly the same geometry (1/2 of the model) you can use the same meshing strategy.
famon likes this.
Old   October 20, 2014, 05:02
amin.z's Avatar
Amin
Hooommm! So great mesh! nice job! bravo!
Best regards,
Amin
Old   October 20, 2014, 06:26
Gweher's Avatar
Gwenael H.
Here is a step by step procedure for your half 3D pipe:
1) Create a "path" sketch in a plane (in my case "Centre_Line_Path" in the XY plane)
2) Create a "profile" sketch in a perpendicular plane (YZ plane with a half pipe geometry sketch)
3) Use the Sweep option create the geometry (see Picture 1)
4) Create a "slice sketch" in the same plane as the profile sketch, in this case you will need 2 sketches for the Ogrid slice, a "upper part" and a "lower part" (here "Ogrid_slice_1", see Picture 2)
5) Use the Sweep option, selecting the "Ogrid_slice_1" as profile and "Centre_Line_Path" as path, replacing "Add Material" by "Slice Material" under the Operation tab in order to slice the existing geometry (See Picture 3)
6) Create a second slice sketch (for the lower "Ogrid part") "Ogrid_slice_2" and repeat the point 5)
7) At the end you will obtain 4 parts, to mesh them as a single entity, select all 4 solid > rmb > Form New Part (See picture 4)
Now you're done with the geometry.
Old   October 20, 2014, 06:45
Gweher's Avatar
Gwenael H.
Now the meshing part step by step:
1) rmb on mesh> Insert> Mapped Face Meshing (see Picture 1)
2) Select all faces (Using the Box select tool to select all the faces)
3) rmb on mesh> Insert> Method and select all 4 bodies
4) Change the Automatic type to Sweep (under Definition>Sweep)
5) Change Src/Trg selection from Automatic to Manual Source and Target (under Definition>Manual Source and Target - see Picture 2)
6) Select the 4 faces of one side as "source" and the 4 end faces as "target" (see Picture 3)
7) rmb on Mesh> Generate mesh (see Picture 4)
8) You can play with the mesh parameters to generate a more coarse/fine mesh
Hope this helped
Azura and AlejandroR like this.
Old   October 28, 2014, 06:22
thanks Gweher for your helpful information
could you help me to mesh the geometry which shown below
it's the grout around the pipe
Old   November 2, 2014, 22:54
Default element boundaries
  #13
i am doing the same thing, forming a new part from the different bodies and then meshing but for some reason my element boundaries dont fall on each other as seen from the picture. could anyone please have a look and explain why?
Old   November 3, 2014, 07:18
Gweher's Avatar
Gwenael H.
hwet, are you sure that the 5 bodies are in the same part? As you import 5 "separated" bodies, the meshing tools meshes them in an independent way without matching the nodes at the interface (see pictures).
Old   November 3, 2014, 07:20
Gweher's Avatar
Gwenael H.
reza67, if you upload your .agdb file I can have a look at it.
Old   November 3, 2014, 13:12
Farzad Montazery
famon is on a distinguished road
Thanks for useful guides, I loved the method
famon is offline   Reply With Quote
Old   November 3, 2014, 15:43
Farzad Montazery
use this way:
mesh>insert>method
Good lock!
Thanks for useful highlights, but this method doesnt support inflation, (inflation deactives in this method)
How can we use inflaton in this method?
Thanks alot
Old   November 3, 2014, 18:23
Thanks Gweher, I guess it was something to do with solid/fluid bodies, but just randomly ansys meshing would recognize these as sweepable bodies and at other times just wont sweep them automatically, even if i put in a method for sweeping with hex, it will say cant sweep these parts, and again at other times would just sweep these regions, see the attached picture of the same geometry but this time only the middle section is shown as sweepable
there are also some tet regions which get poor mesh quality, is it possible for you to have a look at my geometry? thanks
Old   November 18, 2014, 04:46
amin.z's Avatar
Amin
Hope this helped
Hey Gweher!
In the method you described, one simple domain is devised to 5 separate domains!
Is there any way to use some auxiliary lines without deviding domain!? One domain with various local meah! I think it's possible in gambit and ICEM...
Best regards,
Amin
Thread Tools
Trackbacks are On
[ICEM] Simple pipe meshing - problems with y+ in CFX Keizers ANSYS Meshing & Geometry 23 January 15, 2015 09:00
[Workbench] Meshing for perforated pipe buried in porous zone Tanjina ANSYS Meshing & Geometry 0 September 24, 2014 09:41
Using ICEM CFD to repair/edit ANSYS Meshing Kaaji1359 ANSYS 2 July 30, 2013 10:28
[ANSYS Meshing] Migrating from GAMBIT to ANSYS Meshing David-CFD ANSYS Meshing & Geometry 1 April 1, 2011 05:22
[ANSYS Meshing] Ansys meshing with extended meshing jsm ANSYS Meshing & Geometry 6 January 10, 2011 13:09
