[DesignModeler] Rotating the geometry
Old   January 28, 2015, 13:28
Default Rotating the geometry
Ravinder Gill
gill11a is on a distinguished road
Is there a way to rotate a geometry by 90 degress in design modeler. I made a geometry with rotational axis as y axis, but later figured out that Fluent does axisymmetric modelling taking x axis as rotational axis only. So i need to rotate the geometry by a right angle.
gill11a is offline   Reply With Quote
Old   January 29, 2015, 17:17
Kapi is on a distinguished road
Hi Gill11a,
You can rotate the body by "Body Transformation"
Select all the bodies and choose you axis according to fluent and you should be fine
Hope it helps
Cheers
KAPI
Kapi is offline   Reply With Quote
Old   January 30, 2015, 11:01
Ravinder Gill
Thanks Kapi. Worked perfectly
Animation of rotating geometry freddyk STAR-CCM+ 1 December 20, 2012 07:29
Rotating geometry test case zebra Main CFD Forum 0 August 25, 2010 10:34
Rotating Geometry Gearb0x OpenFOAM Running, Solving & CFD 0 July 1, 2010 11:57
question about governing equation in CFX using rotating/non rotating reference frame rystokes CFX 0 January 12, 2010 06:14
vitual _ real deneb FLUENT 3 January 22, 2007 04:31
