[ICEM] Mixed mesh for a combustion reactor
Old   October 20, 2014, 18:29
Default Mixed mesh for a combustion reactor
xha
Jerrydqfan is on a distinguished road
Hi guys,
I want to generate a mixed mesh for a combustion reactor. The detailed configuration of the reactor is attached in the attachment. A .tin file is also attached.
For the eight small nozzles, I want to use tetra and for the rest part (long cylinder), I want to use hexa mesh.
How can I achieve this? I got problems when I tried to merge mesh on the interfaces since the interface the nozzles share with the reactor cylinder only occupies a small portion of the cross section of the cylinder, I don't know how to deal with this.
Any comment is welcomed.
Thank you so much.
Jerrydqfan is offline   Reply With Quote
sliding mesh problem in CFX Saima CFX 46 September 11, 2021 07:38
[snappyHexMesh] SnappyHexMesh for internal Flow vishwa OpenFOAM Meshing & Mesh Conversion 24 June 27, 2016 08:54
[snappyHexMesh] Layers:problem with curvature giulio.topazio OpenFOAM Meshing & Mesh Conversion 10 August 22, 2012 09:03
Mesh used for Combustion Simulation Stein CFX 5 May 14, 2009 18:24
Icemcfd 11: Loss of mesh from surface mesh option? Joe CFX 2 March 26, 2007 18:10
