[ICEM] Scripting: How to set topology tolerance in a script |
October 28, 2014, 12:17 |
François Grégoire
At some point in my script I had to create surfaces (ic_surface 4pts ...) that are very small (surface side length ~0.001 m) compared to the other ones. Icem CFD would refuse to create the surfaces: Surface sides are too small. Check topology tolerance. I looked for hours for a scripting command (thanks to the awesome Icem CFD Programmer's Guide...) that sets the topology tolerance once and for all at the beginning of my script. I found nothing in the guide but after a lot of clicks in the GUI and looking at the generated commands in the Replay Control window, I finally found what I was looking for: ic_set_global geo_cad 1e-4 toler Very convenient command that is not described in the Programmer's Guide. Hope it helps! |
STL import is not working | zordiack | enGrid | 9 | July 1, 2014 14:49 |
[snappyHexMesh] Howto set mesh size tolerance | anothr_acc | OpenFOAM Meshing & Mesh Conversion | 10 | July 28, 2012 13:17 |
[ICEM] Building topology command script files | Anorky | ANSYS Meshing & Geometry | 8 | January 11, 2010 07:25 |
scripting gridgen: why a connector is not saved?? | Tim | Siemens | 2 | July 28, 2007 16:11 |
Help with GNUPlot | Renato. | Main CFD Forum | 6 | June 6, 2007 19:51 |
