[ICEM] How to import .msh mesh and edit it in ICEM? |
November 12, 2014, 06:18 |
Rep Power: 11 |
Hi everybody
I have fluent mesh (.msh) that I have successfully imported to ICEM. Now I want to edit it, more specifically I want to change the resolution/lower the number of nodes. I can't find a way to do this as the blocking tab is not accessible(it is shaded grey). Any suggestions? Thanks |
November 12, 2014, 11:02 |
Ghazlani M. Ali
Rep Power: 28 |
You can't do that, you don't have the geometry, the mesh is already generated. The only thing you can do is to modify it in the mesh tab. you can refine, translate and many more...
June 30, 2020, 11:39 |
Rep Power: 5 |
What if I created the mesh in a different Workbench and want to edit this mesh in a different Workbench Project?
When I try this I have the same problem as Wizze. Thanks a lot! |
July 1, 2020, 03:24 |
#4 | |
Gwenael H.
Rep Power: 20 |
Ali is right; you can only edit a mesh file with the predefined mesh tab in ICEM.
In case you ended up with only a mesh file without the source geometry, you can still regenerate the geometry from a mesh file (can cause some feature loss) and then remesh. With the new workbench releases, starting from 2019R2 (if I remember correctly), you can also directly export a ICEM .prj including the .tin geometry file and .uns (File > Export > Mesh > ICEM) which will allow you much more flexibility. Have fun |
July 2, 2020, 03:28 |
VS
Rep Power: 13 |
The easiest way to do it, without the source geometry, is to use the option Mesh->Facets in ICEM. This will create geometry entities with some loss of detail, as stated above, depending on the complexity of your domain. You can then remesh.
[snappyHexMesh] No layers in a small gap | bobburnquist | OpenFOAM Meshing & Mesh Conversion | 6 | August 26, 2015 09:38 |
[ICEM] Edit .msh file (Fluent) in ICEM CFD | Keizers | ANSYS Meshing & Geometry | 5 | February 24, 2013 13:07 |
ICEM Edit Mesh | blackbody | ANSYS Meshing & Geometry | 3 | March 8, 2010 02:49 |
icem: import tecplot mesh | David | CFX | 4 | August 9, 2006 08:30 |
How to do Geometry from 3D mesh in ICEM | San24 | Main CFD Forum | 4 | August 8, 2005 02:49 |
