[ICEM] 3D duct meshing problem
Old   November 16, 2014, 15:19
Exclamation 3D duct meshing problem
Adnan Nweilati
adnan.nweilati is on a distinguished road
I am new to ICEM , so excuse my ignorance.
For my dissertation, Im trying to replicate this domain and mesh (attached). Its basically a duct and the inlet is in the middle. Finer mesh must be around the inlet.
I have tried every YouTube video/tutorial out there but I failed every time. My problem is that when I open my mesh in Fluent, non of the boundary conditions I set are there (inlet/outlet/walls).
I must be doing something wrong with creating the surfaces and associating stuff together. If you could please try to create this mesh and tell me how to do it I would be very pleased
If you have just a slight idea how to do it please tell me.
Sorry for my bad English.
THANKS!
PS: I already tried to follow this tutorial and apply it for my own project but for some reason that didnt work. http://home.cc.umanitoba.ca/~engsjo/...duct-v1p01.pdf
adnan.nweilati is offline   Reply With Quote
Old   November 17, 2014, 08:09
davide basso
rolloblues is on a distinguished road
Your blocking seems correct. Have you defined all the surfaces you need in your geometry? If so it is very likely an association problem.
In the tutorial you mentioned the association process is made with an automatic function which is super time-saving if it works properly but very often it doesn't. If you did the same maybe something went missing.
I suggest you to do it manually (edge by edge).
rolloblues is offline   Reply With Quote
Old   November 17, 2014, 09:06
Adnan Nweilati
Just to be sure, I have to use edge to surface right?
I choose 4 edges and it should associate it to the surface?
Old   November 17, 2014, 09:17
davide basso
The association is made between edges of the blocks and curves of the surfaces.
Once that all the curves of one surface (geometry) have been associated with the edges of one face (blocking) the association between surface and face is implicit
3-d, duct, fluent, icem
Problem with querying the meshing database in CFX-Pre ashtonJ CFX 18 April 18, 2023 23:49
Duct structure in Wind Tunnel: Continuity problem? JR22 OpenFOAM Running, Solving & CFD 4 April 1, 2013 10:39
[ICEM] problem with meshing in icem cfd saurabhjoshi2011 ANSYS Meshing & Geometry 13 March 12, 2013 11:27
[ICEM] Tetra meshing problem Smaras ANSYS Meshing & Geometry 4 February 21, 2013 09:04
[ICEM] ICEM meshing problem xyq102296 ANSYS Meshing & Geometry 6 October 28, 2010 10:09
