[ANSYS Meshing] What type of mesh to use for a wind turbine that uses airfoil with movable flaps? |
November 20, 2014, 05:15 |
shahriar hossain omee
Rep Power: 11 |
hi
i am trying to do a simulation for the wind turbine that uses airfoil with movable flaps.so both the airfoil and the flap will be the moving parts of the design.what type of mesh can i use for this type of design??? it will be a 2D simulation and i am using ANSYS workbench and FLUENT 13. hope to get a reply from you thanks in advance |
November 21, 2014, 07:27 |
sluzzer
Rep Power: 11 |
U need to set mesh motion. That u can set in fluent & nothing is required on the mesh.
I use cfx. In cfx, I use the rigid body and mesh deformation option, to simulate solid motion inside fluid. There is also an "immerse solid" option in which the fluid and solid nodes overlaps. U can check for similar settings in fluent. |
LES supersonic free jet | martyn88 | OpenFOAM | 22 | April 17, 2015 06:00 |
2D FFD Optimization | RLangtry | SU2 | 2 | August 5, 2014 09:48 |
Error during initialization of "rhoSimpleFoam" | kornickel | OpenFOAM Running, Solving & CFD | 8 | September 17, 2013 05:37 |
pipe flow with heat transfer | Fabian | OpenFOAM | 2 | December 12, 2009 04:53 |
[Commercial meshers] Trimmed cell and embedded refinement mesh conversion issues | michele | OpenFOAM Meshing & Mesh Conversion | 2 | July 15, 2005 04:15 |
