[ANSYS Meshing] How to make structured mesh with correct inflation |
December 22, 2014, 17:08 |
Rustem
Hi everybody!
I try to get structured mesh in a cyclone which profile is a complex curve. The attached picture 1 shows a structured mesh where there was only one criteria - 10 inflation layers with total thickness = 1 mm (for instance, the largest diameter is 133 mm). This mesh was generated using only sizing+bias. The problem now is how to attach to this model just a simple cylindrical tube (see attachment 2) with mapped face meshing and the same inflation layers? I can not get mapped mesh at the face where cylindrical tube contacts with complex curve face because I can not sweep the tube to get mapped mesh. I suppose that I should divide the tube into some elements to get mapped mesh but I do not know how to slice it properly. Probably, I should slice both parts as a single part... Anybody can help me? Thanks for Your attention! |
December 22, 2014, 22:38 |
Rep Power: 14 |
You have to slice the cylindrical tube in 4 parts and then do "mapped face meshing" This link will give you some idea how to slice it and do meshing http://www.cfd-online.com/Forums/ans...tml#post373154 Try to get element sizing of both parts similar. Hope it helps Cheers KAPI |
December 23, 2014, 08:27 |
#3 | |
Rustem
I'll try to detail my question. If the cylindrical tube and a cyclone are in the one part, Ansys mesher shows unmappable face (see attached picture 1). If explode part I get unmapped face mesh (see attached picture 2). The main problem is that the cylindrical tube is tangential to the edge and I'll get close to 0 angles there. If I make smaller mesh in the cylindrical tube there still will be unmapped face like in picture 1. My question is: how to slice the whole volume to get all the faces mapped? Or how should I change geometry to avoid unmapped face? |
Gambit problems | Althea | FLUENT | 22 | January 4, 2017 03:19 |
[ICEM] Generating Mesh for STL Car in Windtunnel Simulation | tommymoose | ANSYS Meshing & Geometry | 48 | April 15, 2013 04:24 |
[swak4Foam] Installing swak4Foam to OpenFOAM in mac | Kaquesang | OpenFOAM Community Contributions | 22 | January 21, 2013 11:51 |
Icemcfd 11: Loss of mesh from surface mesh option? | Joe | CFX | 2 | March 26, 2007 18:10 |
Moving (structured) mesh | Jesper | CFX | 5 | February 2, 2007 03:43 |
