[ICEM] replace geometry
Old   December 26, 2014, 23:50
Default replace geometry
Govindaraju
kmgraju is on a distinguished road
Dear all I have ventury type of pipe. I did meshing in ICEM . I want to change the venturi diameter only. The remaining dimensions are same. how to replace and mesh the geometry with same setup as I did in previous mesh.
Is it possible to simply replace the geometry?
Note: I tried with smaller diameter the associated block went outside of the geometry.
how to create mesh without doing from the beginning
Thank you
Govind
kmgraju is offline   Reply With Quote
Old   January 5, 2015, 09:59
Matthias Voß
mvoss is on a distinguished road
Yes.You need to create unique geometries/names and import them into the ICEM-project.
Create the geometry by hand (SW, Catia) or use the Ansys Workbench with DesignModeler.
Or you create the geometry in ICEM (points-lines-faces) and script the process with the diameter as an input. Be carefull not to change the number of points or lines, since this will cause ICEM to renumber everything and all the associations are gone or at least are in "danger".
mvoss is offline   Reply With Quote
[ICEM] Volume Meshing Problem; YOUR GEOMETRY HAS A HOLE mariachi ANSYS Meshing & Geometry 5 May 30, 2018 02:52
Running CFD parallel. There is no geometry file! CrashLaker SU2 6 April 10, 2014 03:08
[CAD formats] translating geometry from Abaqus to OpenFOAM skuznet OpenFOAM Meshing & Mesh Conversion 3 January 10, 2014 13:49
[ANSYS Meshing] need to convert a cell based geometry into STL or CGNS kamran_kibria ANSYS Meshing & Geometry 0 September 15, 2011 05:14
2D geometry to 3D geometry Sgonzalezg ANSYS Meshing & Geometry 11 April 8, 2011 11:02
