[ICEM] How can i reduce the skewness in this meshing??? |
January 5, 2015, 06:10 |
Duong Tung
Rep Power: 11 |
Hello everyone,
I had a problem with meshing when i tried to mesh a 2D geometry. When I tried to imported the mesh into OpenFoam, I received the information that the skewness was quite high (max skewness: 4.3036) and this influented my results. I want to ask you that how i can decrease the skewness number in my mesh in ICEM. Thank you very much for all your helps! Last edited by gnut1989; January 5, 2015 at 11:31. |
January 5, 2015, 09:24 |
Matthias Voß
Rep Power: 20 |
You need to create a different block-topology for the lower half/ bowl-shaped part. See attached pic.
And you need to make the cuts in upper half perpendicular to the "walls"- just split the whole model first and then apply global grading (e.g. 1mm), then do the wall refinement. |
January 6, 2015, 05:03 |
#3 | |
Duong Tung
Rep Power: 11 |
Thank you very much for your help! Now, I can reduce the skewness in my model |
[Other] Cutcell meshing skewness | RSaid | ANSYS Meshing & Geometry | 1 | December 16, 2014 12:09 |
[ANSYS Meshing] Migrating from GAMBIT to ANSYS Meshing | David-CFD | ANSYS Meshing & Geometry | 1 | April 1, 2011 05:22 |
Urgent help, help pl for meshing problem | Shashi | FLUENT | 8 | October 8, 2008 11:24 |
Best Meshing scheme for Cylinder | Nutrex | Main CFD Forum | 4 | July 29, 2008 11:03 |
Volume Meshing & Face Meshing? singularity of grid | ken | FLUENT | 0 | September 4, 2003 11:08 |
