January 13, 2015, 20:00 |
Meshing/blocking of complex structure
Hi guys, I am very new to the world of CFD and I have some trouble with understanding about blocking and meshing.
I have done a fair bit of the tutorial, but the examples given in the tutorial about blocking/meshing (although helpful for my basic understanding), do not help me in achieving a quality mesh for my geometry since my geometry is more complex compared to the one in the tutorials. My geometry is an impeller, which is enclosed by a cylinder. I want to mesh the volume between the impeller and the cylinder (the area where the fluid flows), and I was suggested to use the blocking method to get a nice premesh. The impeller without the enclosing cylinder (impeller.png) and the enclosed impeller (impellerdonut.png) can be seen on the attachment. So far, what I have tried is blocking the entire area where the fluid will flow and deleting the blocks that are the impeller, as can be seen on blocked.jgp. Am I on the right way? Please guide me so that I can understand this better |
January 20, 2015, 08:27 |
Sebastian Engel
Rep Power: 20 |
The big blocks at the outer radius in blocked.jpg seem to be very distorted. A corner seems to be much bigger than 135 degree... but this appearance could be due to the low resolution of the screen shot. I think it could be a good idea to share your icem files.
[ICEM] Meshing of fluid and solid zone of complex structure through OCTREE | Nils_H | ANSYS Meshing & Geometry | 8 | February 21, 2020 16:34 |
Bottom and free surface level for complex bottom structure | noid | Fluent Multiphase | 0 | July 2, 2014 13:18 |
[GAMBIT] 3D Mesh for complex structure | Shinobi | ANSYS Meshing & Geometry | 40 | December 4, 2012 04:30 |
Meshing complex white-light/GOM based STL models | jola | Main CFD Forum | 13 | January 30, 2012 01:35 |
Gas flowing into a complex structure | syens | CFX | 1 | December 6, 2011 05:25 |
