March 25, 2009, 13:56 |
"segmentation violation" error
^_^
Rep Power: 17 |
Got this error meassage "segmentation violation" many times. For example, when I tried to generate a find grid in ICEM CFD by chaning the maximum element size from 30 to 24. or even when I check a coarse grid quanlity, the error meassage show up! I actually just added 2GB memory which is not the same brand as the old 2G meomry. Will that be a problem? What might be the reason?And how should I deal with it? Thanks in advance. Last edited by Jasmine; March 25, 2009 at 14:30. |
March 25, 2009, 22:49 |
Rep Power: 17 |
Hi!!
Most of the cases of "segmentation violation" error are because of memory problems. You can check it with the task manager if there is any such problem. Other than that, I think you need to work on your geometry for holes or any such defects. |
March 26, 2009, 16:29 |
^_^
Rep Power: 17 |
Thanks!
Well, I changed 2 new memory which is the same brand as my old one, and it works. That kind of error message does not show up so far. |
October 29, 2009, 04:49 |
hashem
Rep Power: 16 |
yes, this error is strongly related to the lack of memory.
October 29, 2009, 07:03 |
Ryne Whitehill
Rep Power: 18 |
I do not think that is the sole case. A coworker and I were getting this message often with ICEM 11. We would basically have to restart the project fresh from the CAD geometry when it would happen. Would use exact same parameters (aka exact same memory usage) and it would work sometimes, others not.
Have not seen this message at all since switching to ICEM 12. |
November 11, 2009, 22:00 |
Clear the memory.
Simon Pereira
Rep Power: 47 |
Hey Ryne,
It may have been that some processes were still running, or at least still hogging memory. For instance, during the tetra process, elements are swapped around or removed. The matrix keeps the memory slots for these cells for a while and may have an issue clearing the memory in some situations. Other times, a process like Prism.exe may continue to run and be hogging memory even after you think it is done. The undo buffer may also hog a lot of memory, for instance, if you did a global mesh edit operation operation like converting linear tets to quadratic (or tet to hex), your memory would hold both the old and new tets so that you could "undo" the operation. Many of these processes, and UNDO its self, were significantly improved at 12.0, which gave us memory improvements, etc. Actually, add mid-side nodes still needs this fix , but at least you can clear the undo buffer easily now. When you were quitting and restarting 11.0, you were clearing your memory in a rough but effective way. I am attaching an image of the memory improvements for Octree Tetra at 12.1 (due out later this month). |
November 12, 2009, 08:12 |
#7 | |
Ryne Whitehill
Rep Power: 18 |
v12.0 has been great, haven't gotten the segmentation violation error with it. However, I am getting a large memory spike on the "disconnecting orphan cells" step of mesh generation. This often crashes ICEM with no warning (i.e. the process just disappears). I submitted a help ticket to the techsupport who confirmed this spike, and they recommended using batch mode until v12.1 comes out to avoid this. This seems to be working, but I often forget to check the box Thanks for the reply, Ryne |
December 20, 2013, 17:06 |
ali
Rep Power: 17 |
I am getting this error in cfx-solve. Any idea how I can resolve this issue?
I have increased the memory allocation factor upto 10 and still getting the same error. I am running CFX remotely on a linux based supercomputer. Thanks |
January 16, 2015, 05:00 |
how to allocate memory for segemental violation error
#9 |
vishwanath
hi every one,
I am finding error as segemental error. how to resolve it? ... can you explain the steps to avoid it. |
Compile problem | ivanyao | OpenFOAM Running, Solving & CFD | 1 | October 12, 2012 09:31 |
Problem with compile the setParabolicInlet | ivanyao | OpenFOAM Running, Solving & CFD | 6 | September 5, 2008 20:50 |
Compiling problems with hello worldC | fw407 | OpenFOAM Installation | 21 | January 6, 2008 17:38 |
DecomposePar links against liblamso0 with OpenMPI | jens_klostermann | OpenFOAM Bugs | 11 | June 28, 2007 17:51 |
user subroutine error | CFDUSER | CFX | 2 | December 9, 2006 06:31 |
