[ANSYS Meshing] ''Contact sizing'' in 2D Fluent meshing
Old   October 20, 2014, 07:30
Default ''Contact sizing'' in 2D Fluent meshing
kaeran is on a distinguished road
Hello everone,
I am new to Ansys Fluent and I am facing a ''contact sizing'' problem between a fluid zone and a solid part. In order to analyse accurate heat transfer between a fluid region and the solid part, the interface boundary has to be properly meshed. Attached is the picture showing an improper contact sizing at the interface.
I have also tried contact sizing feature in meshing but I haven't got what I expected.
Please help me with this....
kaeran is offline   Reply With Quote
Old   October 21, 2014, 09:11
Paritosh Vasava
vasava will become famous soon enough
Try using 'Match Control'.
vasava is offline   Reply With Quote
Old   January 30, 2015, 09:53
Gustaw Cegielski
Goodstuff is on a distinguished road
When I connected two cell zones (both fluid), I opened connections and created a new connection group. Then switched contact to mesh connection, set an appropriate tolerance by means of a slider, and finally, right-clicked at the grop->selected lightning "automatic creation of connections" (i think) and the connection is ready. You could check the connection either by varying the mesh sizes in individual domains and observing, if the stay uniform at the connection region, or by manipulating the display options with regard to the connections. Hope it helps.
Goodstuff is offline   Reply With Quote
Problem with modelling contact in ansys fluent 12.1 mak86 FLUENT 16 August 27, 2019 09:07
problem in using parallel process in fluent 14 aydinkabir88 FLUENT 1 July 10, 2013 02:00
few quesions on ANSYS ICEMCFD and FLUENT Prakash.Paudel ANSYS 0 August 12, 2010 12:07
Polyhedra meshing in Fluent 6.1 mireis FLUENT 1 August 5, 2010 03:42
Meshing problem in fluent loganathan FLUENT 2 July 11, 2002 04:16
