[ANSYS Meshing] mesh quality for simple geometry
Old   February 10, 2015, 02:50
Default mesh quality for simple geometry
Iman
engineer.iman is on a distinguished road
hi,
i'm modelling a flow of water through 1.5 m long and 4" diameter circular pipe.
the geometry it self is simple pipe however the flow is multi-phase with particles thus the mesh quality is very important.
i have created the mesh in fluent as attached.
is my mesh of a good quality? especially the inflation?
how can i reduce the big difference between the inflation elements and the tetrahedrons?
the orthogonal quality is 0.28 min and 0.99 max with 0.914 average.
the skewness is 0.3631e-04 min, 0.798 max and 0.158 average
aspect ratio is 1.1678 min, 16.9 max and 3.9 average
what can i do in this case to improve my mesh?
how can i confirm that this is a structured/non-structured mesh?
thank you in advance
engineer.iman is offline   Reply With Quote
Old   February 18, 2015, 02:11
Iman
any response ?!!
i would really appreciate any advice or comment
Old   March 15, 2015, 21:21
dotapro is on a distinguished road
hai? Did you manage to solve your problem?
dotapro is offline   Reply With Quote
Old   March 16, 2015, 03:44
Paritosh Vasava
vasava will become famous soon enough
The orthogonal quality is good enough and the low skewness is due to the boundary layer.
You can make the mesh elements small by imposing a lower maximum element size.
vasava is offline   Reply With Quote
Old   May 2, 2017, 22:09
Default Hexa mesh
M r . A I R
airforce453 is on a distinguished road
Hi, Did you try Hexa mesh?
(Mesh > Insert > Method), then Let's see in Method Ch, Change Automatic to Multizone so your mesh become to hexa.
hexa mesh is better than tetra I belived that, and also use less than grid to reached quality result. (if compare with equal number of tetra grid)
let's try it. Good luck
airforce453 is offline   Reply With Quote
Old   May 3, 2017, 00:22
Iman
this was an old post from 2015 Looool!!
i manged to improve the quality by reducing the maximum cell size, reducing the growth rate of the cells and increasing the number of divisions at the inflation layer. although the mesh size increased however the quality of the mesh especially at the wall was highly improved
[snappyHexMesh] No layers in a small gap bobburnquist OpenFOAM Meshing & Mesh Conversion 6 August 26, 2015 09:38
[ICEM] Complex Geometry for Hex Mesh smoerebroet ANSYS Meshing & Geometry 0 January 9, 2015 15:21
[Gmsh] 2D Mesh Generation Tutorial for GMSH aeroslacker OpenFOAM Meshing & Mesh Conversion 12 January 19, 2012 03:52
[ICEM] Problem making structural mesh on a surface froztbear ANSYS Meshing & Geometry 1 November 10, 2011 08:52
unstructured vs. structured grids Frank Muldoon Main CFD Forum 1 January 5, 1999 10:09
