February 13, 2015, 05:49 |
Meshing of a curved channel
Rep Power: 11 |
Hi all,
I'd like to mesh a channel whose upper side is a convex curve (think of y=x^2) and study the BL separation along that side. In order to resolve BL better, I used the "Geometric 2" law in edge parameter settings, with the spacing 2 to be "1e-5" and ratio 2 to be "1.2", so as to get a Y plus (based on the physics) of 1.0. Channel width is around 1.0 (meters), and the convex curve is around 0.6m in arc length. The curve is created by an input of 500 points. But here goes the problem: the best I can do for Spacing 2 is 9e-5, if I wanna have a mesh of good quality (angle > 18 deg, determinant > 0.3 say). If I push it a bit further, extremely small angles and determinant start to pop up. I tried to zoom in (a lot) to see what's going on for these troubled elements: I do spot some weird intersection points where there supposed to be only 2 lines crossing each other. (see last pic) I'd appreciate it if anyone can help suggest possible causes for the meshes' low quality. Is it possibly due to precision as I'm forcing the spacing to be very small? Thanks very much. |
February 13, 2015, 09:09 |
Rep Power: 24 |
Try to lower Triangulation Tolerance under "Settings->Model". Choose a value that is e.g. factor 0.1 or 0.01 smaller than your smallest setting for spacing.
February 13, 2015, 10:11 |
Rep Power: 11 |
[ICEM] Meshing a curved Pipe 3D | Daniel_Khazaei | ANSYS Meshing & Geometry | 8 | October 20, 2013 22:11 |
[ANSYS Meshing] Meshing a Periodic channel with high curvature 2D airfoil | ergometer | ANSYS Meshing & Geometry | 4 | February 22, 2012 09:13 |
[ANSYS Meshing] Micro channel waterblock meshing. | codenamew | ANSYS Meshing & Geometry | 0 | January 2, 2012 09:55 |
Thin Channel Meshing in DM | chires | ANSYS Meshing & Geometry | 1 | March 29, 2011 18:51 |
tetrahedral meshing in square channel | Aashutosh Magdum | FLUENT | 4 | May 28, 2005 20:27 |
